Stance SC-5s + Spacers?
I recently lowered on Eibach PK Springs and put some Stance SC-5s on my 09 S Coupe, wondering if 20mm spacers would work all around?
Offsets are currently:
(2) 20x9 +20 offset
(2) 20x10 +35 offset
Tires:
245/35/20
275/30/20
Sitting like this:
(2) 20x9 +20 offset
Tires:
245/35/20
275/30/20
Sitting like this:
I was running the same setup as you last summer..... 20mm spacers all around will not look good at all...... you will bring the front to 0...poking like hell.....the rear you will be able to put a 5mm maybe a 10mm.
Why do you want spacers, it seems quite flush as it is....you just need to go lower....
The fronts are a little tucked right now.. the rears as I see them aren't bad but I'd like them a little wider. Did you have any rubbing with the setup? Also, any pics?
I put the Eibach on yesterday so they haven't settled at all, they're really just place holders because I couldn't stand the gap.. I'm just waiting for the cash flow to go to Tanabe COs
Seraphix, would 10s on front and 5s on back maybe work? I honestly have never had spacers on any car so I don't really know what they can do, I just know the fronts are too tucked for my liking right now.
It would rub with the 10's in the front. I'm running +15 fronts with a 235 on a 9.5" and my fenders are rolled. You can do it but it will rub, I have coils so it's set stiff, a lot stiffer than springs and sometimes there slight rubbing. I think 5's all around should work dude. Then when u get coils go lower, less wide tires and stance it out to your hearts content.
Here is the rear with 5mm dropped on eibach but lower about 1/4 inch more by shaving the upper spring bumper:
at your height 10 would look quite silly.and the front will rub like crazy with anything.........but that's just my 2 cents
hope it helps...
hope it helps...
Thanks for the information guys. Really appreciate it. Think I'm gonna go 5s all around and if shaving is needed then so be it. Really just waiting on the COs with this setup.
BTW, your G is lookin sick burunet.
Kojack
Oct 9, 2015 05:53 PM
nbast
Sep 14, 2015 12:39 PM
