Which spacers would look best for stock 18's?
Sup guys, Im gettin rid of my 20's and going back to stock... would 15mm in the front and rear look flush with no rubbing on stock 18" rims for the 08' journey???
any pics? i cant find anything!
I'd just put them back on and measure exactly what you want. Depends how much you're dropped, if you're dropped pretty low in front and go flush you'll rub the underfender clips. Running a week without spacers is no big deal to make sure you get exactly the spacing you need IMO.
Depends how much you're dropped.....if you're staying dropped.
I have 20mm all around and I'm slightly tucked at -1.8 camber.
Again......bl said it best....just measure what you want then do the conversion to mm and you'll probably be able to get something close.
not looking for negative camber... kinda hard to measure as well.. just wanted to know from the experiences of members
im thinking 15mm all around on stock 18's should be fine????
It's easy to measure once you get your 18s on, just put a straight edge up your tire and measure the distance in mm from the inside of the straight edge to the inside of your fender well (with a couple mm for insurance).
If you've got a aggressive drop you might want to come in an additional 5mm in front to avoid hitting those bumper clips.
Remember, even at 0 static camber, when the suspension compresses, you will get camber.
Majeed Bader
Oct 8, 2015 10:52 AM
