How to fit 20x9 18 and 20x11 20 on G37S?
I'm not the biggest guru on fitment, and really have a simple question. Could I fit a 20x9 +18 in the front and 20x11 +20 in the rear? Keep it mind it has to clear the big brakes from the sport model.
If I could get it to fit, would I need spacers? What about any fender modification (Lowered on Tein S Techs)? What about tire sizes?
Thanks guys!
EDIT: Also, I'm not too keen on offset, it may be -18 and -20 respectively.
Link to wheels
Thanks guys!
Link to wheels
Thanks man! I think they are +18/20, they fit a 370z (manager from company called and told me.) They haven't tried fitting them on a G37 though. I'd be the first!
Anyone know what ET 18 offset is? That's what it says on the site.
Also, this is how they fit a Genesis if that helps. (Not sure if spacers or not)
The Link You Provided for the Wheels Don't even have a 5x114.3 Bolt Pattern.
And yes it can Be Done.But it depends on the Spoke(center) Design and the size of the Back Pad for Akebono Clearance.
20x9+15
20x11+28
Pic:
Here's a good explanation for ET aka Offset
Offset (wheel) - Wikipedia, the free encyclopedia
If those are the same wheels mounted on that Genesis I'd have to say it's +18, +20, they'd be poking out over an inch further if they were negative offsets. Nice looking rims, too bad the bolt spacing is wrong for Gs
OP, you might want to look into AvanteGardes, similar wheels except for the barrels rivets
http://avantgardewheels.com/m350.php
The G in the pictures below is Shuriks, very nice look IMO.
i been looking into the projekt wheels 20x11 in the rears with 25mm offset they use them on the genesis all the time
i haven not ssen many run 11" rims on our cars im not a fan of the poking out of the wheels or having a big stretched tire just to make them to fit,
another option is to put a lot of negative camber also, but dont expect your tires to last long
so if you want to make extreme measure to make them fit they will work anything is posible but depends on how you want it to look
