Work wheels fitment advice
Old Oct 4, 2012 | 10:03 PM
Ra_'s Avatar
Ra_
Guys,
Need your advise on fitment! I've narrowed it down to these Work Wheels Gnosis HS202 Step Lip, in matte silver, for my '12 xS OB sedan, lowered on D2 coilovers. I wanted a semi conservative fit, for daily driving. I didn't want to go staggered, but with AWD, selected the below disk to get that look. I know AWD can go staggered with the correct tire fitment, but prefer not to risk it.
Work Wheel Gnosis HS202 Step Lip
20x9.5 +25 all 4 corners
2.6" lip, R-disk up front (BBK friendly for future mods)
3.5" lip, O-disk in the rear
245/35/20 for tires
How do you think these will look? Would I require any fender work? I'm leaning towards mesh wheels with a step lip, any others I should consider? I've considered SSR MS1 (too expensive), BBS LM (too expensive), Work Brombacher (require spacers for BBK). I ruled out replicas (for now).
Thanks in advance for your input!
Attached Thumbnails Work wheels fitment advice-wheelimage.jpg   Work wheels fitment advice-z34_hs202_bru_01_800.jpg   Work wheels fitment advice-0.58442400-1293443792_617.jpg   Work wheels fitment advice-697_full.jpg   Work wheels fitment advice-701_full.jpg
Old Oct 5, 2012 | 08:52 AM
elrey85's Avatar
elrey85
I think you should be fine in terms of rubbing on all four corners depending how low you go. I have a 2010 X sedan on D2 coilovers also. I have 19x9.5 wheels on all four corners with a finger gap and I do not rub at all. I do have 40 profile size tires and they stick out a tiny bit in the rears but no rubbing at all. Its an agressive look but I like it.
Old Oct 5, 2012 | 12:13 PM
Ra_'s Avatar
Ra_
Thanks for the input! What are your offsets? Also for clarity, no rub even with adult backseat passengers?
Old Oct 5, 2012 | 01:36 PM
G37Pillow's Avatar
G37Pillow
Those wheels look good. I had the VSXX on my old g35 coupe and now have the GS2 on my new g37 coupe. You should be ok with the fenders. At most you will prob have to trim the rear wheel liner which is easy and maybe the rear bumper bracket but thats it. I say get them, you can't go wrong with Works
Old Oct 5, 2012 | 03:01 PM
elrey85's Avatar
elrey85
My offsets are 25mm all around and yes with 4 people in the car no rub. Havent tried 5 people and I hopefully I wont have to lol. Here are pics and like I said its a bit agressive but its to my liking.
Old Oct 5, 2012 | 08:22 PM
Sunny G's Avatar
Sunny G
^^ the tires you are running are too big for those offsets. As for the OP the 9.5 +25 will work fine and if you do have rubbing it might be the fender bracket
Old Oct 5, 2012 | 10:37 PM
silverg37's Avatar
silverg37
yeah his car looks like crap lmao
Old Oct 8, 2012 | 05:08 PM
Ra_'s Avatar
Ra_
What do you guys think of the different disk type to get the bigger lip in the rear, but maintain square fitment for awd? Do you think it's pointless and i should just go staggered and get more lip back there?
Old Oct 8, 2012 | 05:55 PM
bkmax96's Avatar
bkmax96
i think the staggered offset is great..... gives you an agressive look with functionality.....remember whatever you use must function like oem
Old Oct 20, 2012 | 10:36 AM
Ra_'s Avatar
Ra_
Just pulled the trigger! Now the wait begins...
What do you guys think of 245/35/20 for tires? Should I try to get more rubber?
Old Oct 20, 2012 | 01:46 PM
They'll be stretched a bit but should work fine. You might want to go wider in the rear like 265-275, those rims are begging for wider tires back there IMO.
Old Nov 30, 2012 | 05:49 PM
Doggy's Avatar
Doggy
Stretched? ^ thats a fat tire
Old Dec 15, 2012 | 12:05 PM
Ra_'s Avatar
Ra_
Christmas came a little early this year!
Wheels came in much earlier than expected, tracking said next Tuesday. Can't wait to install them in the Spring! Tires are Hankooks Ventus V12 evo K110.
R disk
O disk
R disk vs O disk (square fitment)
DOMO
Old Dec 15, 2012 | 12:12 PM
RdotTeezy's Avatar
RdotTeezy
you wont have any rubbing nor will you need any work. my last set was 10.5 +22 with 275 and no rubbing, driving slammed.
rear run 275
fronts 245
Old Dec 15, 2012 | 12:22 PM
quakerroatmeal's Avatar
quakerroatmeal
It's always so exciting to get new toys. Looks good. Did you consider works vs-xx?
