New Stance SC5 owner
Old Jun 14, 2012 | 03:51 PM
  #31
Trininav's Avatar
Trininav
looks great.. I'm awaiting my sc-5's as well, same drop too. this gives me great visualization as a DD.
Old Jun 15, 2012 | 09:20 AM
  #32
burunet's Avatar
burunet
Originally Posted by TwoThree
I actually don't think it looks that high. Yes most of use would like a little lower, but he killed the gap in the front which looks great and only has a tiny gap in the rear. Perfect for a DD. The Glass TYC Sentra fogs are legit. I sold a guy on here some OEM fogs, and yes they were a little higher quality, but not much, especially considering the price difference! Keep up the good work OP!
Thanks.....Yes the OEM might be of a little better quality, but I didn't think it would justify more than double the price. Four watermelons in the trunk and the rear gap is gone
Old Jun 15, 2012 | 09:22 AM
  #33
burunet's Avatar
burunet
Is the wheels/tires are the same as mine, you'll need to shave the rear bracket a bit...it will rub very slightly on big dips. Just a fyi.
Old Jul 16, 2012 | 09:12 PM
  #34
LftSdDrv's Avatar
LftSdDrv
Hey burunet was wongering how you have the running days going. Don't believe you had to remove a bulb or anything but does this effect your high beams or regular beams.... Ordering aero soon and am considering your set up...
Oh I'm in the Thornhill area postal code 14303 hehe.
Old Jul 17, 2012 | 04:56 AM
  #35
axelamoe's Avatar
axelamoe
Very nice looks clean
Old Jul 17, 2012 | 08:06 AM
  #36
burunet's Avatar
burunet
14303 is the new GTA shipping postal code
There are two ways you can do the fogs. You could have the fogs in the aero bumper running just as the built in fogs, but you would need a relay because there would be too much amperage to have the built in headlights/DRL and fogs all running at the same time.
https://www.myg37.com/forums/d-i-y-i...rt-bumper.html
Or you can do it the easy way, which is what I did, and use the wiring from the built in DRL/fogs and just have the fogs from the bumper. It does not interfere with the high beams or regular beams whatsoever. Hope it helps. LMK if you need help.
G37sPhoton
Oct 4, 2015 11:08 PM
Bennyjoel
Sep 30, 2015 11:56 PM
ajosowiecky
Sep 30, 2015 12:15 PM
