TPMS Question?
Old May 27, 2012 | 11:06 PM
Israel Coelho's Avatar
Israel Coelho
TPMS Question?
Hello there,
I am buying some new rims and tires for my car and I know that once I get the new Rims/tires I will need to put a TPMS on them. I was just wondering if I'd have to buy a new set or are the ones that came on my car reusable. I know I don't NEED them but I'd like to have it installed. Thanks for all the help guys.
Israel
Old May 27, 2012 | 11:16 PM
Rad_Slinger's Avatar
Rad_Slinger
Pretty sure you can use the ones that wee in your old rims.
Old May 27, 2012 | 11:25 PM
HokeClay's Avatar
HokeClay
Old May 27, 2012 | 11:57 PM
this ^, you'll probably have to reset your TPMS though, here's a DIY or you can probably get it done at Discount tire or most better tire shops or your Infiniti dealer. Here's the DIY link~
https://www.myg37.com/forums/d-i-y-i...-for-free.html
Old May 28, 2012 | 12:23 AM
Israel Coelho
Thanks so much guys!! Can't wait to get my new rims and tires.
Israel
Old May 28, 2012 | 07:45 AM
rpm&my_G35's Avatar
rpm&my_G35
You can transfer the TPMS to a different set of wheels.
You do not need to reprogram them as long as the new wheels with the TPSM are going back on the same car.
e.g. I transferred my TPMS from the stock wheels to my 20" wheels and no reset was/is required. Just drive the car for a few miles and the dash light will go off.
Old May 28, 2012 | 10:52 AM
That's good to know, thank for clarifying
Guess i should have put my sensors in my 20s and found that out, but now I'm numb to that dash light
Old May 30, 2012 | 06:47 PM
terrycs's Avatar
terrycs
The stock ones can be used IF the new wheels have enough clearance in the barrel section. If you can't use the predrilled mounting location, you might be able to add another hole on the inside barrel section.
04G35NYC
Dec 24, 2015 01:00 AM
helloandchau
Oct 6, 2015 05:26 PM
Bobo
Oct 1, 2015 10:52 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
