F 19/9.5 +25 r 19/10.5 +30
Old May 10, 2012 | 01:00 AM
ma5aru's Avatar
ma5aru
I'm not to great when it comes to offsets and tires sizes and I'm hoping some of the more knowledgeable here might help. I'm lowered on swift and looking to fit F 19/9.5 +25 R 19/10.5 +30. I will stretch if I have to but as little as necessary would be best (enough sidewall is your friend on most of the rds around here). I'm hoping someone could help me with the proper tire size for my application as well as what else I might need to do to get these to fit. Of course, my goal is to not rub.
2011 G37s 6MT
Old May 10, 2012 | 11:04 PM
ma5aru's Avatar
ma5aru
Hmm...nobody? Do I need to provide more info?
Old May 11, 2012 | 12:22 AM
Sunny G's Avatar
Sunny G
you can run a 245/35 & 275/30 or tire with those offsets would be best. Is your car a coupe or sedan because that helps also
Old May 11, 2012 | 01:58 AM
Kuro's Avatar
Kuro
245/40 and 275/35
Old May 11, 2012 | 03:08 AM
GraphiteG37S's Avatar
GraphiteG37S
Originally Posted by Kuro
245/40 and 275/35
This ...
... assuming the car a coupe?
Old May 11, 2012 | 09:28 AM
TeRRoRiFiC35's Avatar
TeRRoRiFiC35
If you are running a sedan those tires will not work. You will have to go with the combo of 225/40 and 255/35 or 235/35 and 265/30.
Old May 11, 2012 | 09:29 AM
TeRRoRiFiC35
Forgot to add if it is a sedan, you must get an aftermarket camber kit with that setup because you will have to max out the toe and run between 1-2 degrees of camber.
Old May 12, 2012 | 02:34 AM
ma5aru's Avatar
ma5aru
Originally Posted by ma5aru
*snip*
2011 G37s 6MT
Guess everyone missed part of my post..
None the less, thanks for the input.
Old May 14, 2012 | 06:10 AM
ashmostro's Avatar
ashmostro
That could still be a coupe or a sedan......
akk08
Dec 2, 2015 10:08 PM
alxmlr789
Dec 1, 2015 03:55 AM
Kojack
Oct 9, 2015 05:53 PM
abretz89
25
Sep 29, 2015 10:16 AM
JG_G37
Sep 19, 2015 09:07 PM
