An Easier Way to Use the Car Jack
I used my cordless drill to raise and lower the car. Way easier and quicker than hand cranking. At only 7 seconds to go up or down its quicker than my trolly jack.
That jack looks scary!
Get yourself a real floor jack & jackstands. Save the factory jack for when you need to change a tire on the side of the road.
$100 at most costco's.
He already has one.
Trolly Jack = Floor Jack
I didn't mean to suggest someone should crawl under their car with just the factory jack. On a flat cement garage floor I 1. Raised winter tire slightly off ground 2. Removed winter tire 3. Installed summer tire 4. Lowered car. It was fast easy and safe with the factory jack and I didn't bend the ends of the jacking points. If someone was going to use their jack anyway, than as the title says, this is "An Easier Way to Use the Car Jack"
^^Tom, in the context of internet forums, anything is possible.
I read on a different site (kia I think), about someone using the emergency jack to give enough clearance to perform an oil change. I had that in the back of my mind when I replied originally. This kid/guy is convinced it's safe to do so.
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
