Help 20/25mm spacers with G37S coupe OEM wheels??
Old Oct 28, 2013 | 11:58 AM
randyg37s's Avatar
randyg37s
Originally Posted by Rad_Slinger
I put 20mm all around. Pics are in my profile if you want to see. Dropped on Tanabe So-C coils.
thanks bro it looks very nice im thinnking on going that route 20mm all around with stocks
Old Jan 10, 2014 | 04:04 PM
Mpag96's Avatar
Mpag96
Sorry to bring back kind of an old thread but, if you have the stock wheels with stock tires on there would you want to have 20mm all around? Or still stick with the 20 up front and 15 in the back, in the future I plan on getting rims and maybe lowering it but would 20 all around be better then?
Old Mar 26, 2014 | 04:51 AM
LiTo's Avatar
LiTo
i'm on the same page as you mpag96 and would also like to know.dropped on powertrix coilovers here
Old Mar 26, 2014 | 08:42 AM
Give this a look, should be able to get the right fit w/ a bit of measuring at home~
Old Sep 9, 2014 | 06:33 PM
FRESHG37S's Avatar
FRESHG37S
is your tire height 45 40?
245s on the front 275 on the rear.
20mm on the front, 15mm on the rear.
No its not a typo!!
You increased the rears by 30mm with 275s, 15mm in and out.
you increased the fronts by 20mm on the fronts, 10 mm in and out.
So you actually increased your track by 5 more mm in the rear, by going 15mm spacers in the rear, and 20mm in the front,
the track stays even front to rear.
Also 20mm on the rear makes the tire stick out, Im set to factory specs
on camber.
Is your tire height 45 front 40 rear?
Old May 11, 2018 | 04:35 PM
ElG37s's Avatar
ElG37s
Originally Posted by g37nightrider
This is perfect for what I'm looking for. Any other specs outside of tires and spacers?How is ride comfort on the swifts? Any rub or vibration? Verrry clean!
hey, my g37s coupe is lowered and I got the TS1 body kit, I’m running oem wheels atm but I feel like I need spacers, what do you guys recommend?
Old May 11, 2018 | 04:39 PM
slartibartfast's Avatar
slartibartfast
I feel triggered that you resurrected a four year old thread to ask this question.
I have the coupe 19s on my sedan and the rear is fine, the front could benefit from a 20mm spacer. It's a personal choice on your part.
All that said, welcome to the site.
Old May 11, 2018 | 05:15 PM
ElG37s's Avatar
ElG37s
lol i didn’t check the date, thanks
jayrdong
Oct 25, 2015 10:00 PM
james6980
Oct 9, 2015 01:28 PM
amciner28
Sep 7, 2015 08:50 PM
RoyalG37
Aug 11, 2015 12:21 PM
JohnsG37x
Aug 2, 2015 07:33 AM
