Wheel spacers F&R size difference?
Old Oct 11, 2012 | 11:32 PM
  #61
blackvr4tt's Avatar
blackvr4tt
Just to clarify what spacers will work with this setup:
Tires - 245 F x 275 R
Springs - Swift (1.5 front, 1.0 rear drop)
Spacers - ?
Rear spacer - what is the largest spacer that I can go that wont rub? I would like to go at least 20mm.
Front spacer - I also want to go at least 20mm but considering 25mm - I don't want the wheel to be tucked.
If anyone has a few pics of this setup it would be appreciated!
Old Dec 7, 2012 | 03:27 PM
  #62
Italia311's Avatar
Italia311
Hey OP car looks great! are those 20mm all around? I plan on ordering some asap!
Old Dec 9, 2012 | 06:37 PM
  #63
jon23's Avatar
jon23
Thanks a lot! I have 15 mm spacers all around. I will be installing the front and rear camber kits next week, so that should straighten the tires a little for me to see if I need bigger spacers. I'm happy with the current rear setup, but sometimes I think I should've gone with the 20mm spacers for the fronts.... We'll see what happens after the install.
One word of advice, do NOT go cheap on spacers! Lots of horror stories with cheap spacers causing vibrations. Don't forget to torque the spacer's nuts regularly as well.
Old Dec 10, 2012 | 03:19 AM
  #64
ko3r's Avatar
ko3r
jon 23, you are dropped on eibach springs 1.2 rear and front?
Old Dec 10, 2012 | 10:41 AM
  #65
TVPostSound's Avatar
TVPostSound
Spacers - ?
20MM front
15MM rear:
Pic in my album
Old Dec 10, 2012 | 04:18 PM
  #66
jon23's Avatar
jon23
I honestly did not measure the specific drop I ended up with, due to the fact that all springs are different. Therefore some will notice a bigger drop than others. In my case, I wish my fronts would've dropped 1/4-1/2 inch more...
Eibach advertises an average drop of 1-1.5 inches with their Pro Kit, which is what I purchased.
Old Nov 7, 2015 | 03:09 AM
  #67
VelisG37s's Avatar
VelisG37s
@G37Sam Is this recommended for the 245/275 setup?
Old Mar 3, 2017 | 01:42 AM
  #68
Ryanb1223's Avatar
Ryanb1223
I've read all of this great info and searched for over two weeks as not to try to make it seem as I haven't done my research. I have a question and I know this thread is old but I dropped my G coupe on tein springs and need new tires but wanna keep factory look but more aggressive stance. My stock tires are a square setup is 225/50r18 all around. I would most likely do one of these setups on my factory 18x8 rims.
1- 225/50 front and 245/45 rear
2- 235/45 front and 255/45 rear
3- 245/45 all around
Which would work the best as this is my daily driver?
I'm leaning twards 1 or 3 but would like to know spacer size on those as to be completely flush with body and no rubbing or need for fender roll. Any advice would be greatly appreciated.
Thanks,
Ryan
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
Intake
Dec 25, 2015 09:38 PM
news1213
Dec 16, 2015 11:06 AM
james6980
Oct 9, 2015 01:28 PM
connoisseurr
Sep 20, 2015 04:14 PM
