Thoughts on General Tires for G37s?
Old Nov 15, 2011 | 11:34 PM
Airick637's Avatar
Airick637
Hey Guys,
My mechanic recommended getting "General Tires" instead of Hankook Ventus V12's because of the longer tread life?
Suggestions?
Old Nov 16, 2011 | 12:05 AM
37driver's Avatar
37driver
I've had the Hankook's on the rear of mine for about three thousand miles. While I realize that's not a ton of miles the tread still looks as good as the day I put them on. I really haven't noticed that huge a difference in handling between the two except in the rain, the kook's are much better. As soon as the front Stone's wear out I will definitely be replacing them with Hankook's.
Old Nov 16, 2011 | 02:24 AM
audtatious's Avatar
audtatious
I have not tried General tires but Hankooks have a 280-ish AA rating? They won't have tons of longevity. I only had 12k-ish on mine before replacing but that was not the tires fault but camber. I now have ContiExtreme which are a 540-AA rating and should technically last almost 2x the V12's. From a General perspective the G-Max is 480-AA.
Obviously manufacturers specs may be somewhat off.
Old Nov 16, 2011 | 08:17 AM
Aismail's Avatar
Aismail
Honestly I don't suggest u go with either ... U might be interested in a thread I posted two weeks ago
https://www.myg37.com/forums/g37-cou...r-my-baby.html
Old Nov 16, 2011 | 09:44 AM
Coprolite's Avatar
Coprolite
One is summer and the other is all season and have good reviews. Probably the budget choice in each category imho.
Old Nov 16, 2011 | 06:52 PM
Itchytoe's Avatar
Itchytoe
As a general rule, longer tread life means less traction. Are you willing to sacrifice traction for longer tread life?
Old Nov 16, 2011 | 07:06 PM
audtatious's Avatar
audtatious
Hankook V12 is not a bad tire. Decent traction and pretty decent wet handling. Price is not too bad either. If you use them year round they do get slick in cold weather until they heat up somewhat...
I'm running ContiExtreme DWS
Old Nov 16, 2011 | 07:07 PM
audtatious's Avatar
audtatious
Sometimes....Both tires are AA rated.
Old Nov 16, 2011 | 07:22 PM
Airick637's Avatar
Airick637
Guys thanks for the help. Im just curious how these tires perform and if they'd be the smarter decision over the Hankooks for pure economics of the situation. I drive on a lot of hills, manual transmission, and we don't get snow out here in San Francisco but roads get wet quite often
Old Nov 16, 2011 | 07:40 PM
t_hart's Avatar
t_hart
I have General GMax on my car, they drive pretty good imo, drove in some major rain yesterday, gunned it a a red light, no tire spins, I myself was shocked! The tires are brand new, so I cant comment on the actual tread life, but minimal road noise, they look good, seems to have good grip on corners, & rain. Hope this helps...
Old Nov 16, 2011 | 07:41 PM
Itchytoe's Avatar
Itchytoe
Those ratings don't compare across brands. A Goodyear AAA rated tires will perform better in whatever category it's rated in, than a Goodyear AA rated tire. Hankook AAA is better than Hankook AA, but Goodyear AAA isn't equal to Hankook AAA. There's no universal standard for those ratings. They're just whatever the tire manufactorer wants it to be. Some have higher standards than others.
Old Nov 17, 2011 | 03:30 PM
audtatious's Avatar
audtatious
Same can be said with anything UTQG related including treadwear. There is supposed to be a "sicientific method" to get those ratings but no guarantee it happens.
In general you have a performance car and should not expect the associated tires to last as long as those of a Prius
JoshB
Oct 15, 2015 03:08 PM
mitchlt
Aug 20, 2015 03:44 PM
dAgent
Aug 19, 2015 06:49 PM
Hiryuu
Aug 7, 2015 07:08 PM
