Akebono n vossen cv2
^ no the xS doesn't come with the BBK and a few other 'S' things. You get the front fasia, side sills, headlights, seats, paddles and pedals.
My OEM Sport wheels are front 18"x7.5" +45 and rear 18"x8.5" +50. I can tell you the fronts only clear the brake by about 5mm.
Using either of these you should be able to determine if your CVs will clear the BBK.
Wheel Offset Calculator
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Sorry guys I was out of town... Here are my specs
20x9 +32
20x10.5 +45
What size and width wheels are you running with the +38? You can always add a spacer to get the clearance too. Vossen offsets should be the same though for the same wheel though.
20x9 +32
20x10.5 +45
ck1109
Oct 15, 2015 11:06 PM
