help with tire issue plz
Old Aug 10, 2011 | 08:35 PM
1BadAssG's Avatar
1BadAssG
Hey guys recently I upgraded my stock 17s to sport 19s with continental extremeContact tires.
245/45/19 front
275/45/19 rear
The issue I'm having is that my car feels worse than my 93 camry when driving.
At the beginning the car was pulling to the right, so I took it back to tire shop to figure out what it is. They swayed the times around and it fixed the issue a little bit, but after about 2000 miles, the pulling got stronger and I could hear the tire limping.
I took it again to the shop and they swapped the Rona around but now its worse than ever.
BTW, I took it for an alignment but there's wasn't anything offset.
Please help me out as its bugging the hell out of me.
PS: I'm thinking about going back to my stock 17s cuz my 19s experience has been so bad.
Old Aug 10, 2011 | 08:41 PM
Doggy's Avatar
Doggy
Maybe incorrect balancing? Not sure why that would happen, are the stocks bent?
Old Aug 10, 2011 | 08:42 PM
1BadAssG's Avatar
1BadAssG
They did balance 2 times already and no the rims are not bent or even have any curbs
Old Aug 10, 2011 | 08:44 PM
Doggy's Avatar
Doggy
from what I know the car would only pull from the alignment, Theres plenty of member here running the sport 19s with no issues. post a pic, Im curious to see how it looks with those tires
Old Aug 10, 2011 | 08:53 PM
1BadAssG's Avatar
1BadAssG
The alignment shop said there's no issues with alignment whatsoever. Also I'm thinking I should swap to my 17s to see if the pulling is still there.
Also here's a pic
Old Aug 10, 2011 | 10:20 PM
OB G's Avatar
OB G
Pulling left to right has to do with alignment issues. Have you tried a different alignment place?
On the bright side, wheels look good on the car!
Old Aug 10, 2011 | 10:30 PM
trcb777's Avatar
trcb777
I just went from the stock 17s to sport 19's. I was running your setup 245/275 and I thought the car felt great. You must be having alignment problem. I did have 275/35 on the rear.
Old Aug 11, 2011 | 12:02 AM
1BadAssG's Avatar
1BadAssG
If alignment issue then why does it lessens up when I swapped the fronts around? Also it has a "dup dup dup" noise when driving under 40 mph even with my windows closed and stereo off.
Old Aug 11, 2011 | 11:50 AM
sniper27's Avatar
sniper27
i have 225/45/19 and 245/40/19 and have no issues. maybe it's the tires and the size of your front tires?
Old Aug 11, 2011 | 12:30 PM
DadsTaxi's Avatar
DadsTaxi
If they say the alignment is not off and the wheels are true, are the tires cupped or flat spotted? Might explain the dup dup noise. Just a thought.
Old Aug 11, 2011 | 01:06 PM
gymboarder's Avatar
gymboarder
I did the same thing as Sniper with my 19's. I have not had any issues at all.
Old Aug 11, 2011 | 01:11 PM
gymboarder's Avatar
gymboarder
Here is a white sedan with the rims. They are the 25th anniv. ones.
Old Aug 11, 2011 | 01:39 PM
OB G's Avatar
OB G
^^yeah or maybe a bubble forming on one of the tires...
Old Aug 11, 2011 | 03:50 PM
1BadAssG's Avatar
1BadAssG
How can I resolve any of the issues?
Old Aug 11, 2011 | 04:12 PM
The tires & wheels will have a warranty, and if it's not an alignment issue then it falls back on the wheel &/or tires. The place you bought them from needs to make this right after all other potential causes have been eliminated.
I've got 20" rims w/ 245/35s all around and it rides perfect. Since you didn't have any pulling prior to your 19s I seriously doubt it's an alignment issue unless they bent something during the install. The flop-flop at low speeds may be your tires working out the flat spot caused form parking for a long time but moreso in cold weather, and it goes away after a mile or two usually once they're warmed up. Good luck w/ this and BTW, nice looking shoes
