tire rotation
Old Aug 10, 2011 | 07:17 PM
chogrilla's Avatar
chogrilla
tire rotation
makin a trip down to the dealership in a few weeks. planning on asking for a tire rotation bc car is just about a year old now. from those with experience, how much should i expect to pay for a simple tire rotation? no idea what the proper amount is on average.
Old Aug 10, 2011 | 10:43 PM
OB G's Avatar
OB G
Not sure if you have the Base, X, or S. But if you have an S you can't rotate your tires. Otherwise it shouldn't cost more than 50 bucks and shouldn't take any more than 20 minutes. But if you're going to the dealership to do other work to your car ie oil change, they might rotate them for free.
Old Aug 10, 2011 | 10:46 PM
_ant_'s Avatar
_ant_
^ this is dead on.
Old Aug 10, 2011 | 11:40 PM
hobbs's Avatar
hobbs
Local tire shop should not be more than about $30 for rotation and balancing.
Use this to find a quality local shop.
Find a Recommended Installer
Old Aug 11, 2011 | 11:49 AM
mummy2's Avatar
mummy2
Mr Tire does free rotations.
Old Aug 11, 2011 | 01:43 PM
2008G-Man's Avatar
2008G-Man
I think that's providing you bought the tires from them.
Old Aug 11, 2011 | 02:23 PM
SpinG37X's Avatar
SpinG37X
I see you in NYC, which dealership?
Old Aug 11, 2011 | 03:07 PM
mummy2's Avatar
mummy2
It doesn't matter. Look on their website for the coupon.
Old Aug 11, 2011 | 04:24 PM
3Pedals's Avatar
3Pedals
on my previous cars (98, 01 montero sports,01 acura 3.2 CL-S,08 acura TL), before i got staggered fitment, i used to rotate them on my own using the spare tire....gives you a good chance to clean your wheels properly.
also helped that i had a friend who owns a tire shop so after if i had any concerns i'd bring it to him and he'd balance for me if need be.
Old Aug 14, 2011 | 09:59 PM
chogrilla's Avatar
chogrilla
legacy infiniti..so far so good with them..no bad experiences yet
Old Oct 18, 2011 | 05:23 PM
HoustonG37S's Avatar
HoustonG37S
so since the tires are different sizes you cant do a traditional roation. But could/should you swap lefts for rights or are the tires directional (i have Hankooks). If so, how often should you do this?
Old Oct 18, 2011 | 06:00 PM
OB G's Avatar
OB G
If they're directional you definitely shouldn't. What type of hankooks do you have? If have the V12s then no you're SOL. No rotating.
Old Oct 18, 2011 | 07:51 PM
ReddieG37's Avatar
ReddieG37
With directional tires, you can't technically 'rotate' tires but you can swap from left to right and vice versa. The rotation of the tires will still be the same, but will be on the other side of your car. Doing this helps especially if you are lowered and you get more inner tire wear. Once you swap them, the inner side will be on the outer. This however requires unmounting tires and re-balancing.
Old Oct 18, 2011 | 08:32 PM
OB G's Avatar
OB G
^yeah I knew that... Do people actually swap tires though? I feel like that takes alot of extra work and most don't go through the trouble. Plus this puts you at more risk of scratching your wheels up.
Old Oct 18, 2011 | 08:33 PM
A_Palaroan's Avatar
A_Palaroan
if you have staggered wheels then you have to remove the tires, remount and balance from side to side.
