what size spacers
Old Jun 26, 2011 | 11:50 PM
08_g37s's Avatar
08_g37s
what size spacers
I have an 08 s coupe dropped on eibach pk front and tein -h rears and was wondering what size spacers to get a flush-ish look. i am on the stock 19s 225 245 and have -2.5 camber in the rear (no camber kit) and i am willing to cut the carpet wheel liner/the bracket too(how hard is this)
thanks
Old Jun 26, 2011 | 11:56 PM
OB G's Avatar
OB G
20 mm f/r should give you the look you're after.
Old Jun 27, 2011 | 12:07 AM
Devildog37's Avatar
Devildog37
+1 ^^, I have 15's all around on 245's and 275's. The rear is pretty flush while the front is sucked in just a little. No cutting required.
Also, use the search function, I'm sure I've answered this question at least 5 times.
Old Jun 27, 2011 | 01:05 AM
Loi's Avatar
Loi
if you want flushness, you need at least 25mm. 15-20mm would give you a nice stance but not flush.
Old Jun 27, 2011 | 01:16 AM
surfjax87's Avatar
surfjax87
It's all relative to what your version of flush is. Anything from 15-25 mm set the tires nicely. Measure it out if you want. Use a ruler or such and measure perpendicular from the wheel/tire and decide for yourself. Also, search through the forums for pics and find the look you're after.
nbast
Sep 14, 2015 12:39 PM
si_driver
Sep 13, 2015 12:04 PM
JPat94
Sep 13, 2015 10:35 AM
ZSpeedPerformance
Supporting Vendors
Sep 4, 2015 11:09 AM
