Volk Formula Lugs rant
Old Jun 27, 2011 | 06:32 PM
J2S2M's Avatar
J2S2M
Originally Posted by Kidcane
Because they are open ended water can collect and just sit in there and rust out the stud and lug. Then it seizes up and mess up the stud or lug or both. So I found if you just smear some axle grease or something on the inside or all over the stud before you put them on it will help protect it from rusting out.
Everytime I wash my car, I use some compressed air to get out any moisure around the lugs to prevent this rust you are referring to.
Old Jun 29, 2011 | 06:14 PM
terrycs's Avatar
terrycs
Putting grease on the studs holding the wheel is considered a no-no.
To keep the anodized AL caps from seizing to the lug nut, I put a little moly grease on the threads and have never had a problem since.
As for the plastic key, it will also last longer after you start using moly grease on the lug cap.
Old Jun 29, 2011 | 06:28 PM
Kidcane's Avatar
Kidcane
Florida G Club
There ya go folks...molly grease. I have never had a problem though.
Old Jul 1, 2011 | 09:18 PM
jmlenz's Avatar
jmlenz
+1 for Muteki R40. All metal everything and about $80...look better than the Volks IMO too
Stevolkz33
May 28, 2016 02:36 AM
Depravity
Oct 16, 2015 01:37 PM
djdiskino
Oct 7, 2015 08:31 PM
*ICE*
Oct 5, 2015 03:05 PM
