245 all around
Old Apr 30, 2011 | 06:47 PM
Frankyg37s's Avatar
Frankyg37s
245 all around
would i lose performance or anything else if i run same tires,245s all round instead of the stagered fitment.
i have spare tires thats why i ask?
THANKS
Old Apr 30, 2011 | 08:55 PM
fairladyz34's Avatar
fairladyz34
nope, youll be fine. People that track their cars usually prefer a square set up because of better turn in predictability
Old Apr 30, 2011 | 10:13 PM
gimpy's Avatar
gimpy
I'm about to do the same thing so it's good to here another confirmation from a member.
Old Apr 30, 2011 | 11:20 PM
J2S2M's Avatar
J2S2M
Running 245/35/19's currently and ran 245/40/19's for couple of years w/o any problem on my RWD sedan. Btw you don't lose any performance, but you get the benefit of being able to rotate your tires. Staggering is not really necessary unless you are running multi-piece wheels with lips.
Old May 1, 2011 | 12:41 PM
Frankyg37s's Avatar
Frankyg37s
OK GOOD im going to run 245/35/20 all around on my rwd 6mt coupe on stagered wheels
Old May 2, 2011 | 12:38 AM
J2S2M's Avatar
J2S2M
Why would you run same tires on all four if your wheels are staggered? I actually thought your wheels were not staggered. I guess you have some spares lying around. I would still purchase 2 more tires and run the appropriate sizes on the staggered wheels.
Old May 2, 2011 | 01:11 AM
Loi's Avatar
Loi
^+1.
If your wheels are staggered but the wider rear wheels should have wider tires or else the rear would be stretched and the front wont, and it's not going to look pretty.
Old May 2, 2011 | 08:49 AM
soundmike's Avatar
soundmike
Originally Posted by Loi
^+1.
That's true, although at least on the '07/08 sedan's, the stretch/bulge is already the case with the OEM's with the fronts running 225s and rears at 245s with an inch narrower front rim.
In any case, a square set-up is fine. I've run 245's and now 255's all-around for the past 51,000 miles with no issues.
Old May 4, 2011 | 03:19 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Will be fine running a square set up. Helps reduce under steer also.
Old May 11, 2011 | 07:13 PM
sniper27's Avatar
sniper27
so can you rotate them if you run the square setup even though the front wheels are 8.5 and rears are 9?
Old May 11, 2011 | 07:36 PM
J2S2M's Avatar
J2S2M
You can only rotate em side to side unless you are willing to dismount and remount the tires. You wouldn't be able to rotate em like non-staggered setups because your wheels are still staggered.
Old May 12, 2011 | 08:09 AM
gugarci's Avatar
gugarci
Would love to see some pictures to see how the front would look compared to the rear.
akk08
Dec 2, 2015 10:08 PM
kcg37
Sep 15, 2015 11:21 AM
Simran Mann
Sep 9, 2015 02:08 AM
drewfinity
Aug 20, 2015 08:17 PM
Rubyq60
Aug 3, 2015 10:36 PM
