How to tell OEM wheel width size???
Old Dec 13, 2010 | 07:01 AM
Igor911's Avatar
Igor911
Hey guys,
I recently had Infiniti warranty swap two of my wheels on the passenger side of my car (Front and Rear). After the swap, I feel as if my car is slightly going to the left and I had double checked the pressure to be 36 all the way around.
I have a feeling they may have installed the rear rim on the front tire, and front tire on the rear rim. Are there any special marking or is there anyway I can find out which width I have installed where?
Thanks for your help.
Old Dec 13, 2010 | 08:14 AM
rks's Avatar
rks
what are the tire sizes? the staggered set-up on the "S" has different sizes for wheels and tires for the front and rear. as far as the wrong wheels on the front/rear; the front hubs have an extra stud to prevent this.
Old Dec 13, 2010 | 08:44 AM
Igor911's Avatar
Igor911
An extra stud??? I've owned 4 other Nissan products before my G and all of my wheels have always had 5 studs.
Old Dec 13, 2010 | 08:52 AM
beerme986's Avatar
beerme986
take the wheel off, on the back of the wheel on the spokes the widths are printed there
Old Dec 13, 2010 | 08:54 AM
Igor911's Avatar
Igor911
Never noticed that, Thank you! Would you by any chance know what the front/rear measurements are supposed to be?
Old Dec 13, 2010 | 09:28 AM
rks's Avatar
rks
should be listed in your owners manual: for the "S" 19x8.5 F 19x9 R. BTW the max PSI I see is 33 F and 35 R. and if you didn't see the extra stud/pin on the front hub, you need to look closer.
Old Dec 13, 2010 | 09:44 AM
WPPJR30's Avatar
WPPJR30
https://www.myg37.com/forums/brakes-...y-offsets.html
Old Dec 13, 2010 | 09:55 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
or just look on the driver's side door sill. there is a placard there with the wheel/tire sizes listed (for OEM only obviously)
Old Dec 13, 2010 | 10:45 AM
da mayor's Avatar
da mayor
only way to visually tell is if the front wheels sit farther out than the rear wheels right now b/c the fronts are 8.5" wide vs 9" rears
Old Dec 13, 2010 | 10:46 AM
Igor911's Avatar
Igor911
it does kind of look that way. Going to take them off after work today to check the sizes of what's written on the inside of the spoke
Old Dec 13, 2010 | 10:59 AM
da mayor's Avatar
da mayor
take it back to where it was installed... have them do it so they won't blame you for anything.
also front tires are 225/45/19 and rears are 245/40/19... i'm sure they can read that
Old Dec 13, 2010 | 04:16 PM
2008G-Man's Avatar
2008G-Man
A wise man once said ..... RTFM
Old Dec 14, 2010 | 06:30 AM
Igor911's Avatar
Igor911
very interesting, i took off the front wheel and it clearly was marked "FRONT" on the inside spoke and the size read 19x8.5J...
Is it possible they could have knocked my alignment out of wack??? STRANGE!
Old Dec 14, 2010 | 07:03 AM
rks's Avatar
rks
1. You can't put the rear wheels on the front without removing the extra stud/pin
2. Your PSI may be too high
3. What was the reason for the "swap"?
4. tramlining
5. take it back to the dealer
6. anything is possible; however unlikely
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
amciner28
Sep 7, 2015 08:50 PM
STownSaint
Aug 29, 2015 09:04 AM
JohnsG37x
Aug 2, 2015 07:33 AM
