Whoever said CV-1's wouldn't rub with a +25 front offset...
Old Aug 6, 2010 | 09:27 PM
davv1215's Avatar
davv1215
what the heck camber and size tire where you running? And what drop? I'm running 245/35 in the front with -2 camber both sides and eibach drop and if I hit a bump, there will be some outer fender rub. My tires is pretty flush to the fender. Looks mean though. Thinking about tanabe fronts to ease it a bit, but I like the lower look.
Old Aug 6, 2010 | 10:52 PM
STOOF's Avatar
STOOF
im running a 20x9 +2 with 225/35/20 and dont rub...AT ALL.
No camber kit or anything and i can tuck it right up under the fender.
Old Aug 6, 2010 | 11:02 PM
Weiboy718's Avatar
Weiboy718
you'll rub at some point but it won't be something you have to worry about too often.
get coilovers and your issues will get better. i'm assuming you're on stock shocks?
Old Aug 6, 2010 | 11:19 PM
jnguyen's Avatar
jnguyen
Get 235/30 or 225/35
Old Aug 7, 2010 | 12:23 AM
davv1215's Avatar
davv1215
I meant + 20 in the front. 225/35?? In NY? I'm in Queens. Pothole and you're done.
Old Aug 7, 2010 | 02:26 AM
STOOF's Avatar
STOOF
yeah big deal, the diff between 225/35 and 245/35 is 7mm of sidewall. Thats about 1/4"
Im in Staten Island, and drive in EVERY borough all the time.
Old Aug 7, 2010 | 02:40 AM
TomieG's Avatar
TomieG
What brand of tire are you running? Different brands run either true/small/large to their actual size.
Old Aug 7, 2010 | 03:58 AM
VossenG37S's Avatar
VossenG37S
I'm on S techs on a +20 front w 235/30/20 and no rubs!!!
Old Aug 7, 2010 | 10:54 AM
TomieG's Avatar
TomieG
Im slammed on coilovers on +13 front with 235/35/19 toyo t1r's no rubbing here.
Old Aug 7, 2010 | 09:12 PM
davv1215's Avatar
davv1215
Running Falken 452's. Probably should've went with 225/35's then. 7mm off of the sidewall may give me some room to prevent fender rub. I went from +32 offsets to +20 offsets on the CV-1's, so I added 12mm's.
Old Aug 7, 2010 | 09:13 PM
davv1215's Avatar
davv1215
Wish I lived in Miami so I could run those stretched tires. I would also be more slammed than my current Eibach's too.
Old Aug 8, 2010 | 12:35 AM
Weiboy718's Avatar
Weiboy718
gotta pay to play!
G37xhibeet
Nov 15, 2016 09:29 AM
Broski28
Feb 9, 2016 11:50 AM
Gio37
Aug 16, 2015 10:12 AM
ddayeg37s
Aug 9, 2015 07:10 PM
Rubyq60
Aug 3, 2015 10:36 PM
