Are Linea Corse Dyna 19x8.5/10's too big for a g37s? will it rub?
Old May 26, 2010 | 11:10 AM
rimast21291's Avatar
rimast21291
Exclamation Are Linea Corse Dyna 19x8.5/10's too big for a g37s? will it rub?
I was looking at my350z.com, came upon a thread about the rims (19x8.5/10 Linea Corse Dyna - Hyper Black (5x114/e15f,e20r) I want to purchase for my car and I'll put the link below, but I was wondering will these rims with 235/35's in the front and 265/30's on the rear rub at all / be too big on a stock g37s?
WheelDude.com | **Introducing the Linea Corse DYNA** Got Lip??? - MY350Z.COM Forums
Old Dec 29, 2011 | 02:55 PM
gtslo88's Avatar
gtslo88
Raising this thread from the ashes. Anyone know much about these wheels? Really like the way the Work Varianza looks, just not the price tag. these seem pretty similar, any input?
Are Linea Corse Dyna 19x8.5/10's too big for a g37s? will it rub?-dyna_1985_hb_2b.jpg
Are Linea Corse Dyna 19x8.5/10's too big for a g37s? will it rub?-dyna_polished_1985_72.jpg
check out the lip
Are Linea Corse Dyna 19x8.5/10's too big for a g37s? will it rub?-img_7354.jpg
Old Dec 29, 2011 | 03:06 PM
gtslo88's Avatar
gtslo88
Offset - 15F/20Rmm
Old Dec 30, 2011 | 03:32 AM
gtslo88's Avatar
gtslo88
BUMP. just got my 08 g37s two days ago and really want to put some wheels on it. I've looked through a few threads but havent really come up with much yet.
Will a +15 offset on a 8.5 inch wheel on a stock height G look right/fit without rubbing. And a +20 off set on a 10 inch wheel fit normally as well?
Really hate the look of the streched tire or extreme negative camber.
If anyone had some info i'd really appreciate it.
Old Dec 30, 2011 | 11:01 PM
gtslo88's Avatar
gtslo88
Somebody has got to know the answer to this. They are made for a g35 and I figure these are common sizes. Just need to know if this will be considerd agressive
Old Dec 31, 2011 | 01:23 AM
fairladyz34's Avatar
fairladyz34
U should be good
Old Dec 31, 2011 | 03:47 AM
gtslo88's Avatar
gtslo88
Thaks fairlady, your car is sick btw. Anyone else have any info. Please dont make me buy rotas...
Old Dec 31, 2011 | 11:01 AM
fairladyz34
Thanks man! And u may need to trim the rear bumper bracket a little just to be safe
Old Dec 31, 2011 | 11:57 AM
WPPJR30's Avatar
WPPJR30
Please do not threaten to buy Rotas because no one has responded. If you buy Rotas you're only putting yourself and your passengers/family at risk.
You should be okay with those wheel widths and offsets. You won't have to stretch your tires too much or run crazy negative camber. I'm assuming you have a coupe, correct?
Old Dec 31, 2011 | 12:13 PM
gtslo88's Avatar
gtslo88
Yes it is a stock height coupe, don't plan on dropping it yet.
I've only had the car for a few days so i need to do some more research on here, trimming bracket, running spacers, ect.
Old Dec 31, 2011 | 12:25 PM
WPPJR30's Avatar
WPPJR30
Just a 'heads-up'... That set-up may look a bit "off" with stock height. Those offsets are moderately aggressive for the G coupe and you should run a little negative camber to pull that off. You cannot do that if you are not lowered.
JohnnysG
Car Care & Detailing
Sep 27, 2015 02:36 PM
maybeg37
Sep 8, 2015 02:33 PM
Abramite
16
Aug 8, 2015 08:35 AM
Rubyq60
Aug 3, 2015 10:36 PM
