20" vs 19" performance.
Old May 18, 2010 | 07:47 PM
oreoleo's Avatar
oreoleo
Could aggressive street drivers run 20" wheels and still get equal performance to the original 19s? For example the lighter Volks G2 in 20". The sidewall would be skinny, but aside from ride comfort, would the performance be equal?
Thanks
Old May 18, 2010 | 07:54 PM
G37Sam's Avatar
G37Sam
With larger wheels it usually a trade off, better handling (shorter = stiffer sidewall) for less straight line acceleration. You also get the advantage of rocking larger brake rotors.
Old May 18, 2010 | 11:56 PM
Greggski's Avatar
Greggski
I have the G2's in 20's and actually noticed better acceleration and braking. Even though they are larger in diameter, there is enough weight savings to off set the larger size.
Old May 19, 2010 | 06:40 PM
amf25's Avatar
amf25
20 in rims have no adverse effect on acceleration because the OD is usually same as stock. I can def feel faster acceleration bc rotating weight is reduced by 16:2. I have 20in G2s too: 8 lbs less on rim+tire per corner compared to stock, so 256lbs equiv dead weight reduction. rim will always be lighter than rubber. now does it translate into getting me faster to work in the morning? hasn't yet haha
Old May 21, 2010 | 05:16 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
A bit better handling/response out of the 20's, slight better ride in 19's. Not talking large difference here but some can tell the difference. 19's will offer more protection to the wheel if you have poor quality roads, but 20's do look good on the car though.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
tt350z
Sep 22, 2015 12:05 PM
kcg37
Sep 15, 2015 11:21 AM
Raffay Khan
Intake and Exhaust
Sep 14, 2015 10:47 PM
infinitiandb...
Intake and Exhaust
Sep 11, 2015 08:26 AM
