275 on a 10.5 rim consider stretched?
Old Mar 27, 2010 | 07:52 AM
beerme986's Avatar
beerme986
i have 10.5 rear wheel with a 275/30/20 tire on it. I didnt notice it at first but there are tons of rock chips around the lip of my wheel. This is when I noticed that the rim lip actually protrudes a tiny bit further out than the tire itself. I thought my tire set up was very common but is this a stretched set up?
I am running the yoko s drives on volk gt30's. my phantoms are chipping like crazy so I am wondering the following:
1. Did my tire place somehow put the tires on wrong that would cause this stretched look?
2. If this is normal, what size would I have to put on so that the tire are futher out than the rim itself (so when the front tires kick back rocks it will hit the sidewall and not the rim itself)
Old Mar 27, 2010 | 08:11 AM
mikelr's Avatar
mikelr
I wouldnt say that 275s are a "stretch" on a 10.5" rim. A wider tire may offer the edge of the rim more protection but not much. What you want to do is select a tire that offers a side wall with rim protection built in, only some model tires have this. It's a thicker rubber section right next to the rim section that offers protection mainly from curb rash but would be very effective at protecting the edges of your rims from rock chips. The Michelin Pilot Sport II's that I run have it.
Old Mar 27, 2010 | 08:17 AM
beerme986's Avatar
beerme986
dammit! these phantoms chip so easy it's driving me nuts. I already dropped $700 + mounting for these tires so I will not be getting new tires anytime soon. guess I will just have to get them repainted during winter and get new tires then x1000000
Old Mar 27, 2010 | 01:45 PM
B L U E S L A T E's Avatar
B L U E S L A T E
Yes.....
Old Mar 27, 2010 | 04:06 PM
beerme986's Avatar
beerme986
so what width should I be running if I want the lip protection from the tire? I did my research on the forum and seemed like anything wider than 275 would rub when dropped on eibachs. guess I have to repaint the lip and get the right tires next time
Old Mar 27, 2010 | 04:20 PM
B L U E S L A T E
Depends on the tire brand and their offering. But I'd assume 295 on 10.5 would be good for most brand. Not sure if they'll fit without rubbing tho.
Old Mar 27, 2010 | 07:04 PM
TJHG37S's Avatar
TJHG37S
It's a tiny bit stretched but not crazy, but I have never seen rock chips on my lips so not sure it's the tires fault.
Wonder what other tires have rim protection, I would like those for my next set!
Old Mar 29, 2010 | 01:13 AM
yogregb's Avatar
yogregb
so which size do you think is better on a 10.5 wheel? 275 or 285? I need to know as i'm ordering wheels and tires now from Lou.( Dropped on tanabe coils)
Old Mar 29, 2010 | 02:37 AM
beerme986's Avatar
beerme986
275 is what most people have so that rubbing is not an issue. 285 and above, the chances of your rubbing are much higher (unless your trim the wheel well lining/move the bumper bracket)
from my experience now, know that 275 on a 10.5 with a yokohama s drive tire will leave the rim lip slightly exposed. grippy tire though
Old Mar 29, 2010 | 11:39 PM
yogregb's Avatar
yogregb
Thanks alot, I'll go with the 275
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Soccer4555
Sep 30, 2015 05:31 PM
pal51961
Sep 27, 2015 08:38 PM
JC-RH
Sep 27, 2015 09:36 AM
