Tire size for Vossen 082 with Eibach
Old Jan 10, 2010 | 04:31 PM
whiddles's Avatar
whiddles
thanks for the info DON
Old Jan 10, 2010 | 04:38 PM
donpisto's Avatar
donpisto
No prob. Anytime
Old Jan 12, 2010 | 01:49 AM
VossenG37S's Avatar
VossenG37S
Ok had it aligned today and very little to almost no rub till I turn and only rubs slightly on rear right! Because my fender liner seems to be hanging and sitting right on tire . I had the rear left slightly trimed and helped a lot now I'm happy and will probably have rear right also trimmed but currently not nearly as bad as yesterday! Like I said those liner in the fender looked like they are pulled down and they are sitting an inch or less close to tire
Old Jan 12, 2010 | 01:45 PM
SteveG37's Avatar
SteveG37
So Diego, I guess there's no way I would be able to squeeze a 10MM spacer into my rears with 285/30/20 coming from the 305's with no spacer if you're rubbing slightly with the 285's and a 39 offset. I spoke to Carlos as AutoGlitz and he told me there's no way I'd be able to put 10MM spacers unless they add more negative camber like I currently have with my 305's. I'm going for the flush look not the hella flush VIP look, so it's tough to get flush w/o stretching tires which is what I really don't want to do.
Old Jan 12, 2010 | 01:51 PM
VossenG37S's Avatar
VossenG37S
Yeah they did everything for me! I!would try a 5mm with 285 but gonnna be close. Remember my fender liner is hanging down for some reason? I don't want to run negative and right now it's flush and perfect
Old Jan 12, 2010 | 01:53 PM
VossenG37S's Avatar
VossenG37S
They did an awesome job ! 285 with my offsets sits perfect and won't change it now, just need spc front camber kit and good to go!!!
Mattlorentzoe
May 24, 2021 08:49 PM
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
