question about offsets 19x9 19x10
Old Jan 11, 2010 | 07:14 PM
pakjj's Avatar
pakjj
Hi,
I was wondering if +34 offset for both front and rears for 19x9 and 19x10 would be alright (no rubbing). The tires are 245/40/19 and 275/35/19. I will be on eibach prokits when the wheels are put. Any input is greatly appreciated. Thanks!
Old Jan 11, 2010 | 07:27 PM
G37Sam's Avatar
G37Sam
You should be fine I believe given that you'll be running around -2 degrees of camber with the drop anyways
Old Jan 11, 2010 | 07:39 PM
BocaIvan's Avatar
BocaIvan
Sedan or Coupe?
Old Jan 11, 2010 | 08:55 PM
pakjj's Avatar
pakjj
coupe.
Would it rub on stock suspensions?
Thanks for your input G37Sam!
Old Jan 11, 2010 | 08:58 PM
G37Sam's Avatar
G37Sam
Many folks are running 10.5" in the rear with a drop and offsets close to what you posted with no issues I believe
Old Jan 12, 2010 | 02:05 PM
pakjj's Avatar
pakjj
would +35 and +37 be better offsets for the coupe?
Old Jan 12, 2010 | 04:51 PM
jran76's Avatar
jran76
The difference between the +34 and +35/+37 is 1-3mm; not much. The +35/+37 will sit further in the fender (more tucked). On a 9"F/10"R rear you can go down to into the mid to high twenties without any issues (no rubbing, no negative camber, or tire stretch).
The offsets you mentioned will be fine, but they will be slightly tucked in. If you prefer for the wheels to be flush with the fender, you need slightly lower offsets (lower offsets will push the wheel further out).
Old Jan 12, 2010 | 05:00 PM
finagle69's Avatar
finagle69
those offsets will be pretty tucked in the front. most people get in the mid-twenties up front.
i ordered a set of wheels @ 8.5"/10" +25mm offsets all around.
Old Jan 12, 2010 | 05:39 PM
pakjj's Avatar
pakjj
oh ok, i think i understand it now. so the take home message is that the +34 offset all around will be fine (no issues with rubbing) correct?
btw, these are forgestar f05's gunmetal. the reason i ask because i have been looking around the forums and it seemed that most people with 19x9 and 19x10 with tires 245/40 and 275/35 had offsets of +35 front and +38 rears, but forgestar told me +34 all around so i was confused and worried about rubbing.
Thanks for your inputs guys!
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
nomorecivicsi
Sep 10, 2015 03:58 PM
carid
Supporting Vendors
Sep 10, 2015 10:17 AM
joshferbs
Sep 9, 2015 08:53 PM
Simran Mann
Sep 9, 2015 02:08 AM
