Help Offset kings, need your help
Old Nov 13, 2009 | 05:42 AM
STOOF's Avatar
STOOF
Im on this current setup, offsets are after spacers.
20x9 +7 - 225/35/20
20x10 +12 - 245/35/20 - Rubs very very slightly on turns.
It depends whether youre gonna stretch tires or not to see how flush you can go.
If you go with 245/35 - 275/30 setup with those offsets you should be fine. Highly doubt youll rub. You might even need some small spacers, like 5s.
I also completely cut off the bumper bracket, as its really not even needed and i rubbed it no matter how much i trimmed.
Old Nov 13, 2009 | 10:35 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
Finally gettin rims for the camel I see
Old Nov 13, 2009 | 08:38 PM
Greggski's Avatar
Greggski
Originally Posted by G37Sam
I think I'll be ordering some 20" wheels soon just need some help as the offset numbers seem scary, want to see if anyone is running anything similar (calculations tell me they might be too much, hoping someone could prove me wrong)
FR: 9" wide +25 offset
RR 10" wide +25 offset
Running around -1.8 degrees camber and dropped on Eibachs
What do you guys think?
Heres what I am running:
FR: 9" with +25 offset - 255's
RR: 10" wide +30 offset - 285's
Camber is right about -1.2 in the rear. I rub a little on the fender bracket (even after I grinded it down) over bigger bumps. However, if I moved down to a 275 and took out some more camber, I would most likley not rub at all. Also, I am on KW's and am a little lower in the rear than eibachs, and alot lower in the front.
Old Nov 14, 2009 | 11:41 AM
G37Sam's Avatar
G37Sam
Thanks for chiming in guys, thing is, those of you with coils don't have as much as rebound as us with stock sport suspensions, which is why you might not rub as much, guess we'll have to find out then
Old Nov 14, 2009 | 11:43 AM
SOLISIMO's Avatar
SOLISIMO
Sam your on Eibachs stop being a Ninja, dude it sucked not talking to you I had to communicate through Jqueen
Old Nov 14, 2009 | 12:16 PM
G37Sam's Avatar
G37Sam
Haha likewise Solis, it was unfortunate we had to communicate through JQueen
Man on my current setup, I'm dropped on Eibachs, my rears are rubbing a little with the 20mm spacers
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
