how wide
Old Sep 1, 2009 | 03:39 AM
boss23's Avatar
boss23
how wide
how wide can a coupe g37 18inch tires hold 225? is stock can i go wider?
also i wanna make my rims stick out a little bit more i have to put wheel spacers what do you guys recommend
and can you answer that ? on the 19inch rims ?
Old Sep 1, 2009 | 10:01 AM
G37Sam's Avatar
G37Sam
H&R & Eibach are some good brands for wheel spacers.
Old Sep 1, 2009 | 11:06 AM
Loi's Avatar
Loi
I'm pretty sure you can go as wide as 245, possible 255 on the stock 18x8 rims.
Old Sep 1, 2009 | 11:08 AM
demuslee's Avatar
demuslee
According to Tiredirect you can go as wide as a 255
Old Sep 1, 2009 | 11:23 AM
nogoodname's Avatar
nogoodname
whats the widest possible for 10.5 inch wide rims for the rears without hitting and rubbing
Old Sep 1, 2009 | 12:10 PM
JKashat's Avatar
JKashat
I got 305's on my 10.5" wide GT30's with KWv3's and SPC rear camber kit. Had to (slightly) trim the inner felt linner like a 1/4 inch. No rub. Love it.
Old Sep 1, 2009 | 12:12 PM
JKashat's Avatar
JKashat
Go for the 255's all around on your 18's and just do spacers on the rear to give it the appearance of being staggered.
Old Sep 1, 2009 | 12:46 PM
Loi's Avatar
Loi
I would go with either keep the stock tire width or 235 and go with 15 mm spacers all around for that "rim fender flush" look. if you maximize your tires and add spacers, you might have a rubbing problem due to the fact then you tires will bubble out farther than your rims.
Old Sep 1, 2009 | 01:05 PM
2GoRNot2G's Avatar
2GoRNot2G
I picked up the 20 mm spacers I'm running on my G off eBay for $75 / pair. It looks like they have now raised their price to $88 / pair, but that's till a prety good deal considering they are the bolt on type, so there's you don't have to change out studs, and they are also hubcentric.
Old Sep 1, 2009 | 01:45 PM
madmax2k1's Avatar
madmax2k1
Do the spacers require any special tools to install? Or do you just bolt them on?
Did you get any wheel vibrations or alignment issues since you installed the spacers?
Old Sep 1, 2009 | 08:51 PM
boss23's Avatar
boss23
im thinkin about gettin 245s all the way around, will i get any rubbin problems? with spacers on them i want the back to stick out more its too into the fender how many mm spacerwould i need and do i have to put any thing in the front spacers ?, and i heard 235s are max for the front wheels around here any comments?
bri
Nov 23, 2015 11:35 PM
Victory
Sep 28, 2015 10:49 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
Slapshot1
Sep 27, 2015 08:40 AM
botlfed98
Sep 22, 2015 12:30 PM
