18 x 11 + 21 on slightly modified fenders?
Got a question, would 18 x 11 + 21 offset wheels fit on a G37 with slightly modified fenders (roll, mild pull, with modified liners). Or is it better to do 10.5/11 wide.
Would they clear an upgraded brake kit?
Thanks
Thanks
depending on what type of wheel ordered, some may clear your brake kit some may don't, it depends if its a high disk or not in the front. For the real normal disk should clear it also.
If i were you, I wouldn't buy 18s period, too small for our cars, it'll look like toddler tires.
You won't need modded fenders either, that will be depending on the tire size you buy and how much camber you're running.
Kojack
Oct 9, 2015 05:53 PM
mmnjtwa
Sep 7, 2015 02:27 PM
