Official Low Offset/Hellaflush Thread
Old Dec 22, 2011 | 09:58 AM
  #1081
TeRRoRiFiC35's Avatar
TeRRoRiFiC35
Originally Posted by Wyldfyer
fairladyz34 and G37Rider92649:
I really respect what u guys did with your ride. Do any of you run spacers or just found wheels that fit the G37s. I KNEW this was going to be a problem with wheel options but i HAD to have the s. Im looking to grab some wheels soon. Thanks
Custom wheels can be cut to clear the calipers of the OEM BBK if you have it. I'll just name a couple: DPE, HRE, IForged, ISS Forged, D2 Forged, Rotiform, VIP Modular. All these will run you anywhere from $3500-7000 depending on brand and size.
Old Dec 23, 2011 | 01:00 PM
  #1082
1cleanG's Avatar
1cleanG
NextLevel Performance
^^correct. You choose your disk size, your wheel width, and offsets. This is the only way to get a true custom fitment for a car, and def the best way(aka: not having to run spacers). This also allows you to produce the most amount of lip or concaveness depending on what style of wheels you like.
Old Dec 23, 2011 | 01:04 PM
  #1083
Doggy's Avatar
Doggy
I want a big lip. Still confused about how it works. I know the disk is a part of bigger lips. Somewhere said that the lower the offset the bigger the lip, which makes sense. So a 20x10 with a lower offset is a bigger lip than a 10.5 with a higher offset?
Old Dec 23, 2011 | 01:31 PM
  #1084
1cleanG's Avatar
1cleanG
Originally Posted by G37Rider92649
im bagged, and 99% of my pictures show the fender sitting on the wheel, it took alot of calculation and gauging to do that, people dont realize when I ride up the wheel totally pops out. People ride low on their set up and its aggressive, looks sick actually, except if they had my set up it would not even be drivable without pulled fenders. My wheels look like they're about to fall off when I'm driving lol. But I love it LOL
nice man, PM me n we can chat about bags, UAS got a new set up for bags that will cost u less than 1500 bucs, equivalent to the air runner (exact same!!) set up thats 5k, and same as the air lift kit thats 2k+ without the cheesy front shocks it comes with. We got it on our team members g35 ill post a video some day.
I'm actually planning on bagging my '05 FX35. Have you ran into any problems w/ your stock components at all? I know you mentioned you drive your car A LOT, so I want to be prepared for anything going wrong after installing it.
unforunately nope. Higher = Rides like a luxury car, car lower = stiffer, more performance. Remember, your bag replaces a spring and acts like a spring, not only you can control your height, you can control your stiffness too. I don't see a different from when I had coils, I threw on sway bars and gt-spec underbraces too, I feel pure performance. Unless your riding really really high than nvm lol
One of my buddies has baggs and the lower he sits, the bouncier it gets because of the amout of motion the bag can move, and the more air/higher its raised(yes, 4x4 mode), the ride because smooth and stiff. This is the same reason why many people switch to a bag/coil setup, so that way they can still be stiff when slammed.
Old Dec 23, 2011 | 01:41 PM
  #1085
1cleanG's Avatar
1cleanG
This depends. Your disk size plays a HUGE roll in your lip size. There's usually 3 types of disk:
1. BBK
2. Normal
3. Agressive
The more your spokes have to curve to reach around the Brakes, the less lip your wheels will produce.
If you do a standards side by side of the same disk, then yes, a 10.5" wheel with the same offset as a 10" wheel will have a larger lip. The lower the offset, its straight lip size.
Example: +30 offset will give you 30 MM less of lip then a +0 offset. When you go in the negative offsets, its the same(just like temperature). The lower you go, the more lip you get.
I did a CRAP tone of studying of all of this when I ordered my Work wheels because living in MN, i knew I had limitations of how small of a tire I could run to not crack a wheel.
This is a great website to use as a reference and put it in perspective as well. (i put this in calc as an example)
http://www.rimsntires.com/specs.jsp?...&text1=&text2=
Old Dec 23, 2011 | 01:51 PM
  #1086
fairladyz34's Avatar
fairladyz34
Let's use a ten inch three peice wheel width for example. Say the offset is plus 0, or center of the wheel. That would result in a 5inches for the outer barrel width. Then you add the face of the wheel which needs to clear the brakes. This is where the disk, face, backspacing, etc. comes into play. If you need a big caliper clearance you may only have a 3.5" lip because you would need the clearance. However if you only need to clear a smaller take size you can use a shallower face and having a larger lip while the wheel width and offset are the same.
Old Dec 23, 2011 | 05:31 PM
  #1087
InvaderXiN's Avatar
InvaderXiN
1. BBK
2. Normal
3. Agressive
http://www.rimsntires.com/specs.jsp?item=Wheel-Tire size comparer&sw1=275&ar1=30&bd1=20&rw1=10.5&et1=30&sw2 =275&ar2=30&bd2=20&rw2=10.5&et2=0&text1=&text2=
Quoting this information again, since it is good information and deserves to be on this page twice.
Also remember that general rule of thumb is just to purchase wheels that do clear larger calipers, in case there is ever that chance that you want to get one later down the road.
I failed to do that with my WORK T1S and had to run spacers when I ended up getting an OEM brembo kit.
Old Dec 24, 2011 | 01:12 PM
  #1088
G37Rider92649's Avatar
G37Rider92649
I hate math lol. More negative more aggressive, but higher disk smaller lip. More room for BBK less fatness your lip is going to be. For front use High DIsk no matter what, whatever disk it takes to fit a big BBK, unless you know youll never get one than do medium or normal disk. For the rear you can do a normal disk and youll still fit your bbk.
.. i want new wheels lol
Old Dec 24, 2011 | 04:21 PM
  #1089
Doggy's Avatar
Doggy
Dam great info. Thanks guys! So let's say I have 2 wheels. Both same disks, one is a 20x10 +0 and the other is a 20x10.5 +6 would the lip size be the same? Or would the 20x10 have a bigger lip
Old Dec 24, 2011 | 06:46 PM
  #1090
fairladyz34
^probably almost exact same. If not the same. Best way to find out is to ask the company making the wheels
Old Dec 27, 2011 | 03:50 PM
  #1091
fairladyz34
Sorry for the crappy pics, rainy day FTL. Anyway heres a pic of my newest set of wheels, slightly less aggessive than my ISS's that were 9.5/10.5 +10. Ill take better pics as soon as the weather is better.
19" Varrstoen 2.2.2
Limited Edition Black Chrome
Front: 9.5" +12 w/ 225/45/19 Hankook V12
Rear: 10.5" +12 w/ 245/40/19 Hankook V12
Old Dec 27, 2011 | 04:12 PM
  #1092
TeRRoRiFiC35
I'm not in love with the color combo for some reason... Something just is throwing it off for me
Old Dec 28, 2011 | 01:49 AM
  #1093
Kuro's Avatar
Kuro
A lot of great info here, thanks guys
Old Dec 28, 2011 | 02:05 AM
  #1094
Doggy's Avatar
Doggy
Fairlady I like it. What's your camber at driving height and how high is it?
Old Dec 28, 2011 | 02:41 AM
  #1095
ShyAznB8oi's Avatar
ShyAznB8oi
hey doggy, whats your front camber set at?
