Official Low Offset/Hellaflush Thread
Front - 9' +5 offset (includes 15mm spacer) 235.30r20 - Hankook V12
Rear - 10.5' +20 offset (includes 5mm spacer) 255.30r20 - Hankook V12
I believe that is correct.
? guys, are hankooks more of a square tire? I"m considering moving from T1R's to V12's, but I heard they're more square?
I found t1R's for only about 100 bucks more for a full set so I think I may just stick w/ T1R's...
I don't know if it's only hankooks but 275/30/20 did not work on the +25
So it's either Toyo T1R or General UHP i'n 265/30/20 that will work on that rear +25 other wise just run 255/30 wich i still prefer to have the look i want.
Josh keep that set-up you are set cause if u try to run hankooks again it Won't work especially w your drop. You set bro, my buddy has 20/25 offsets and tried hankook 245/275 and rears where a no go, so we swapped out for Generals UHP 235/35 265/30 and guess what perfect fit :0
Josh you got a go with the KW Varient 3's because they are so adjustable. What was your thought on the question about Hankook's being "more of a square tire" since you just had them. The OP's question on offsets would certainly matter with tire shape as well.
yeah. It is true that Hankooks sidewall are more Squarish, term people use is "Bulkier". So Let's say we are comparing Falken 452 and Hankook V12s.
Even tho they are exact same sizes both brand being 245/35/20 285/30/20
You will more likely to rub with hankooks cuz of bulkier sidewalls.
