Official Low Offset/Hellaflush Thread
Old Jan 8, 2016 | 09:14 PM
  #2041
nguyenp1's Avatar
nguyenp1
Originally Posted by b-drizzy
Get some true tires
some hankooks can do the job
What tire size is the rear ?
I would just raise it about half inch and that will make a difference
if anything its a better for you and will stop damaging the G lol
Which hankooks should I get? I'll raise my car too. I got 245/35s in the rear. It sits perfect in the back and barely scrapes. Thanks for info. Definitely helped.
Old Jan 11, 2016 | 04:01 PM
  #2042
b-drizzy's Avatar
b-drizzy
Hankooks v12
They little pricy so maybe start looking in the threads if you can come up on a set of them
or check local tire shops for new or used maybe youll find some
that's how I do my search and usually come up on them just take your time, for meanwhile
Might as well finish rocking that nankag since its already installed on the wheel lol
Old Jan 17, 2016 | 06:36 PM
  #2043
J Rad's Avatar
J Rad
Damn I miss this car.. 19x10.5-33 front, 19x12-30 rear
Attached Thumbnails Official Low Offset/Hellaflush Thread-image.jpeg
Old Jan 19, 2016 | 01:03 PM
  #2044
b-drizzy's Avatar
b-drizzy
more piks plz
Old Jan 29, 2016 | 01:54 PM
  #2045
VQHAY's Avatar
VQHAY
What tire options do I have? Im looking to find a perfect tire size with no stretch to fit 19x9.5 +22 wheels. I have a G37x coupe so Im looking to run square wheel/tire setup.
Old Jan 29, 2016 | 02:23 PM
  #2046
b-drizzy's Avatar
b-drizzy
this is not the thread for you then lol
Old Feb 1, 2016 | 04:12 PM
  #2047
VQHAY's Avatar
VQHAY
Unfortunately :/
Old Feb 2, 2016 | 01:57 PM
  #2048
j50ny's Avatar
j50ny
I have a question and I'm hoping someone can assist. I'm trying to decide on a set of wheels and I currently have my eye on a set with the following specs: front 19x9.5 -10, rear 19x10.5 -26
I have an awd EX35 and it's getting lowered on Fortune coil overs. Next year, I'll be putting in a custom air ride setup.
My question...What size tires to get a nice, stanced look and keep the AWD system from going crazy? Should I lean towards a square setup and save myself from a possible headache?
Guess that was 2 questions.....thanks in advance
Old Feb 3, 2016 | 12:28 PM
  #2049
b-drizzy's Avatar
b-drizzy
I suggest a square setup for being AWD
And don't know too much info for specs on a EX since this is a G forum lol
but specs seem pretty deep dint know if that can actually work with you
If I were you I saved that cash from wheels and get full AIR system and that will just be perfect, and sell the fortune coils before you go any further
Airlift and outcast will have some good deals soon
Old Feb 3, 2016 | 08:15 PM
  #2050
j50ny's Avatar
j50ny
Thanks for the info b-drizzy. I'll start looking at square setups a little more. Most of the guys around me with extreme setups (that I see) have VW's and are on bags. I'll pick some of their brains also. Maybe seeing the car and taking some measurements will help me decide on the best wheel specs. Trying to get everything in order for spring/summer
Old Feb 4, 2016 | 01:03 PM
  #2051
b-drizzy's Avatar
b-drizzy
Got Cha!
GL on it, post some piks here when you finish the EX I would like to see that done
Don't really see them on the slammed game often lol
Use Google to help with specs and other forums you'll find the answers
Old Feb 15, 2016 | 09:05 PM
  #2052
Swaggy G's Avatar
Swaggy G
ESR Sr01
Hey guys I've been reading through threads but haven't been able to piece together an answer. My question is what would be necessary to fit 19x9.5 +22 front and 19.10.5 +22 on my G37s. It is not lowered and is completely stock. Is it even possible to fit on my factory tire specs? They're Hankook Ventus V12's. I also don't plan on lowering the car right now since it's my daily and drive it very often. Thanks.
I just used the calculator and got these results but I'm a noob so I'm not really sure what they mean.
Inner Clearance:
12.7mm less
Outer Position:
extend by 12.7mm
Diameter difference:
-0.26" (-0.96%)
Old Feb 16, 2016 | 12:38 PM
  #2053
b-drizzy's Avatar
b-drizzy
If your going to be completely stock
then yes they will fit but it will look little funky
Is this going on a sedan or coupe ?
Old Feb 16, 2016 | 02:15 PM
  #2054
Swaggy G's Avatar
Swaggy G
It's the coupe with sport suspension. How funky are we talking?
What if I did 19x8.5 +30 and 19x9.5 +35?
Old Feb 17, 2016 | 11:57 AM
  #2055
b-drizzy's Avatar
b-drizzy
Like the wheels will stick out and look like a 4x4 with stock suspension lol
but if its on a coupe it should be ok, you have a bit bigger rear fenders will it will look ok, this is a coupe on 10.5 rear with stock suspension
hope that help for you
