is this bolt of any use
unscrew that bolt, remove the collar around it, and screw it back in and it helps pop off the rotors so your not stuck bashing a good rotor to get it off if its seized.
if you remove that bolt, the threads can rust and prevent future use.
Idiot bolt? Not really, just a simple, cheap device used to prevent issues.
ck1109
Oct 15, 2015 11:06 PM
