G37 OEM wheel & Tires (Specifications) *For Reference*
Old Feb 24, 2009 | 12:30 PM
Coupe OEM 19" 10 spoke Sport wheels & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other:
Lug Nuts~flat shoulder, mag-style w/ washer, 2.7oz/76 grams each.
OEM wheel locks- 3.2oz./91 grams each.
Center caps .3oz./14 grams each.
TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Sedan OEM wheel specs~
G37 Sport and G37x Sport
Front: 18"x7.5". Cast aluminum-alloy. Bolt pattern 5x114.3 Offset +45. Weight 24 pounds (per Rochester)
Tires: Bridgestone Potenza RE050A P225/50R18 95W
Rear: 18"x8.5". Cast aluminum-alloy. Bolt pattern 5x114.3 Offset +50. Weight 25 pounds (per Rochester)
Tires: Bridgestone Potenza RE050A P245/45R18 96W
18" non-Sport
18x7.5 front/rear. Cast aluminum-alloy, Bolt pattern 5x114.3. Offset +43mm
17" non-Sport
17x7.5 front/rear. Cast aluminum-alloy, Bolt pattern 5x114.3. Offset +45mm weight 22.2lbs (thanks 4DoorFury)
Spare
17x4T Cast aluminum-alloy, Bolt pattern 5x114.3. Offset +30mm
18x4T Cast aluminum-alloy, Bolt pattern 5x114.3. Offset 0mm
Last edited by slartibartfast; Jan 21, 2019 at 12:35 PM. Reason: added Duckfeet weights
Old Feb 24, 2009 | 12:34 PM
SubSurface's Avatar
SubSurface
Are you selling these, or just posting specs?
Old Feb 24, 2009 | 12:35 PM
Posting specs for reference. Some of these questions get asked a lot and I've never seen anyone post the specs.
Old Feb 24, 2009 | 04:18 PM
Thrillhouse's Avatar
Thrillhouse
I appreciate it, I was just looking for this.
The stock wheels can hold 245/40 on the front and 275/35 on the back right?
Old Feb 24, 2009 | 04:27 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
^ Correct
Old Feb 24, 2009 | 04:37 PM
Graham's Avatar
Graham
I'm gonna edit your the thread title and sticky it, if you don't mind BB.
If you've got some similar info for the OEM 18's would be good to add just for reference.
Old Feb 24, 2009 | 05:08 PM
SubSurface's Avatar
SubSurface
Might want to add bolt patern>>>5X114.3
Old Feb 24, 2009 | 05:14 PM
That's what I put it here for. I actually weighed these myself, don't have the 18's available to me to weigh. I'm sure someone has a set that's off of their car.
Now if anyone ever read the stickies...
Good call! Added.
Old Feb 24, 2009 | 05:56 PM
Graham's Avatar
Graham
Well it's stickied, hopefully members will read it if they need some info.
Old Feb 24, 2009 | 06:17 PM
If anyone has accurate info on the 18" non sport wheels or something else pertinent, please post up for everyone's benefit.
Old Feb 24, 2009 | 07:12 PM
DrJones's Avatar
DrJones
Wow! I didn't realize how heavy our wheel/tire combos where.... thanks for posting this Jeremy
Old Feb 25, 2009 | 11:14 AM
G37ChadATX's Avatar
G37ChadATX
perfect timing Jeremy. i just wanted to know that info. seeing as in a few months i will have to replace those rear tires, i was curious the widest to fit the 9' rear wheel.
Old Feb 25, 2009 | 11:23 AM
amoney805's Avatar
amoney805
Great post BB. I was looking for some of this info.
Old Feb 25, 2009 | 11:26 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
Hmm.... Still no offset info though. The mystery remains.
Old Feb 25, 2009 | 11:43 AM
TomG37's Avatar
TomG37
Does anyone know the offsets of the stock wheels, that would be really helpful!
