Do speed ratings have to be the same?
Old Nov 18, 2008 | 04:04 PM
wrathletik1's Avatar
wrathletik1
Here is my problem. I need a new rear tire and am calling different shops. Nobody has the W rated tires, but I can get Y rated one. Our stock tires are all W. Is it ok to run a higher Y rated tire with the 3 W's or should they all be the same?
Old Nov 18, 2008 | 04:15 PM
finagle69's Avatar
finagle69
perfectly fine. you can even run a lower speed rated tire as long as you don't exceed the recommended speed for said tire.
Old Nov 18, 2008 | 08:37 PM
w0ady's Avatar
w0ady
yup its ok but how worn out is the other rear tire? if its been on there a while, id recommend replacing them both so you have matching tread.
misc
29
May 24, 2023 03:57 PM
4DRZ
Nov 7, 2015 08:32 PM
Detailed Image
Lighting/Cleaning Products
Sep 28, 2015 07:02 AM
deky_
Sep 12, 2015 11:02 AM
