More wear on outside
Old Nov 4, 2008 | 06:03 PM
goredcar's Avatar
goredcar
I have 4,000 miles on the Potenzas... and just took them off and put on winter wheels. I was surprised to see uneven wear on all four tires, with the outside wearin more than the inside. It is pretty significant... does anyone else have this problem?
Old Nov 4, 2008 | 06:20 PM
purebullet417's Avatar
purebullet417
i believe that means you have some camber problems. probably should go get an aliment to fix that. are you dropped?
Old Nov 4, 2008 | 06:30 PM
PSYH's Avatar
PSYH
Post Whore
Outside wear = positive camber, which is rare because I believe our cars come with slight negative camber. (citation needed)
Old Nov 4, 2008 | 06:32 PM
Kidcane's Avatar
Kidcane
Florida G Club
^^What he said.
Old Nov 4, 2008 | 06:33 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
Yeah, outside wear is not typical. What pressure are you running?
Old Nov 4, 2008 | 08:23 PM
goredcar's Avatar
goredcar
I have had the car for about 3 weeks. It had 32 PSI when i got it so I assume that is what the previous owner was running. The car is not dropped... that may lead to inside wearing I think...
I have brand new tires on winter so I am guessing that I better get it in for an alignment right away. It just seems strange to me that all 4 tires had the same problem... and to the same extent.
Thanks for the replies guys!
Old Nov 4, 2008 | 09:20 PM
speedracer g37's Avatar
speedracer g37
outside wear may result from lots of hard cornering by the previous owner.
Old Nov 4, 2008 | 09:53 PM
G37RacerX's Avatar
G37RacerX
I concur
Old Nov 4, 2008 | 10:01 PM
G2Envy's Avatar
G2Envy
Low tire pressure would result in the outside of the tires wearing. Too much pressure would cause the middle of the tires to wear.
I keep mine inflated at around 45. I would try adding more air when summer rolls around again.
Old Nov 5, 2008 | 12:38 AM
goredcar's Avatar
goredcar
Wow... 45 PSI... that seems pretty high for a car tire. Is that what you guys are running in the Potenzas? If the tires were underinflated wouldn't both inside and outside be worn?
Old Nov 18, 2008 | 05:02 PM
gshb's Avatar
gshb
the sticker on the car says to do 35 psi cold. i think 45 is high.
for wear patterns: http://www.procarcare.com/includes/c...dtirewear.html
Old Nov 18, 2008 | 08:34 PM
w0ady's Avatar
w0ady
ya seriously, 35 psi is what normal people run. have you checked your alignment specs yet?
Old Nov 18, 2008 | 10:24 PM
VIP G's Avatar
VIP G
lol mine wore heavy on the inside because of my drop. My fronts are fine and wearing evenly though. I still have stock fronts at 18k and they look great. Vredsteins on the rear and they're sick
Old Nov 19, 2008 | 02:43 AM
Skyline-LEXY's Avatar
Skyline-LEXY
Take it to the dealership i think they give you free alignment check.
Old Nov 19, 2008 | 08:31 AM
Loi's Avatar
Loi
yes i have the same problem. but i just dropped my car on eibachs so maybe itll wear out the inside more now and eventually even out.
