Stupid TPMS
Old Feb 12, 2008 | 07:03 PM
RedlineSi's Avatar
RedlineSi
Stupid TPMS
Ok, so since the day I got my G 2 months ago my TPMS light has been on SOLID all the time. No flashes, no blinks, nothing. I finally got it in today to get fixed. That lasted all of a couple miles and it was on solid again. All the tires are at 35, that isn't the issue. I can't find anything in the manual about a simple solid light. Anyone have any ideas? I am going to have to take it in again anyways since they ordered me that tow cover that was missing in my front grill, but this is getting annoying. The car is fantastic minus the stupid light. Do you think I have a bad sensor?
Old Feb 12, 2008 | 07:06 PM
Flyingcesar's Avatar
Flyingcesar
I think its a bad sensor...
Old Feb 12, 2008 | 07:07 PM
OPen Class's Avatar
OPen Class
According to the dealer:
If any one tire is out 2 psi from any other tie the light trips. IF the tires are all at a specified level that is not what the computer says it shouldbe, the light trips. Say the computer is set for 32 and the tires are at 35, light trips.
I was told I can have the computer set to a specific pressue so when we get new tires we can run brand specific pressures.
Take it in and have them validate all this. Some guys at the dealer are not familiar with how it really works.
Old Feb 12, 2008 | 07:09 PM
IP37's Avatar
IP37
raise them to 40 and see if it goes away then bring back down to 35
Old Feb 12, 2008 | 07:15 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Wrong, the TPMS comes on when the tire pressure is below 26-28psi (I forgot the exact number its been a few years..) it has nothing to do with one tire being less inflated than the other. It's just a bad sensor and they need to do a better job at finding out what the problem is instead of reseting the ECU and sending you on your merry way. And yeh the light should come on ~20 minutes after driving. You haven't changed your rims have you?
Old Feb 12, 2008 | 07:44 PM
RedlineSi's Avatar
RedlineSi
Nope Diamond, stock wheels. I do live in Minnesota, and the cold can obviously mess with them, but that isn't it at this point. I agree, they should've looked further into it.
Old Feb 12, 2008 | 07:59 PM
G-WIZ KID's Avatar
G-WIZ KID
Raise them to 36psi and have them reset. I had the same issue. 36psi is key.
Old Feb 12, 2008 | 09:53 PM
solopresident's Avatar
solopresident
sucks man. try what G wiz said if he lives in the cold to and has the same problems.
good luck
Old Feb 12, 2008 | 10:24 PM
DiamondGCoupe
No, the tires (as stated on the driver door panel) are supposed to be at 35psi all around. Therefore, 36 is purely coincidence (hey that rymed). Like I said before the sensors will not come on until the tires are lower than about 26-28.
Old Feb 12, 2008 | 11:31 PM
RedlineSi's Avatar
RedlineSi
Yeah, 1 psi isn't going to change it. I still think I have a bad sensor.
Old Mar 28, 2009 | 02:26 PM
TJHG37S's Avatar
TJHG37S
Mine came on and my lowest pressur was 33 psi....the dealer put on aftermarket 20s and it went on whlie i was driving it home. bad sensor you think?
Old Mar 28, 2009 | 03:25 PM
aznutx's Avatar
aznutx
i dont think i quite understand, so u have after market wheels, with reseted tpms. and then they just went on mid drive? if so maybe check psi's again, if that isnt the case, then probably failty sensor maybe damaged during the transfer?
04G35NYC
Dec 24, 2015 01:00 AM
pal51961
Sep 26, 2015 10:36 AM
jgronline
Sep 21, 2015 08:44 PM
JG_G37
Sep 19, 2015 09:07 PM
Thirty_Seven
Sep 18, 2015 11:34 PM
