TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Itb12-027 7at important update.
Old Nov 13, 2014 | 10:27 AM
  #31
BaapsG37's Avatar
BaapsG37
Funny thing is I noticed the lag after a few weeks, which made this thread very interesting. I did make my own grounding kit with the help of AZg37 and installed it a few days ago. Gotta say, the shift is much better than what it used to be, and honestly its not in my head. Not sure I will look into the update any further in the off chance my shifting gets worse...
Old Nov 18, 2014 | 03:32 PM
  #32
G37Xtreme's Avatar
G37Xtreme
Has that bug been worked out of the Consult 3+ cable yet, or do you still need to do Consult 3 to get the interim update, and then Sonsult 3+ to get the final update?
Old Feb 8, 2015 | 06:38 PM
  #33
itzricky's Avatar
itzricky
Question:
Does resetting my ECU, reverts the programming of ITB12-027 7AT Fix which addresses Acceleration lags
Old Feb 17, 2015 | 06:56 PM
  #34
drkay's Avatar
drkay
Originally Posted by itzricky
Question: Does resetting my ECU, reverts the programming of ITB12-027 7AT Fix which addresses Acceleration lags
Nope! You are ok to reset the ECU.
Old Jul 28, 2015 | 03:25 PM
  #35
SunnyG's Avatar
SunnyG
Last week I brought my 2011 G37X (I bought it used early this year) to a dealership and told them about the rough downshift of 2->1 gear. After the work was done, the work order shows they update it ITB10-075. The rough downshift has improved but not completely gone. However, major improvement on upshift. The upshift is more responsive and smoother.
Just curious, do I need to reset the ECU after the update?
Old Jul 30, 2015 | 11:36 AM
  #36
djdiskino's Avatar
djdiskino
Anyone notice their transmission shifts strange in DS mode while coasting in traffic on a hot-humid day.. This car just like my maxima does not like humid/hot weather.
Old Aug 9, 2015 | 09:28 AM
  #37
mezzo's Avatar
mezzo
Green Eyes!
I'm in AZ so I know about hot days. The strange shifting you are referring to, is it shift flaring? Like its almost hanging on to the gear to get to the next?
Same issue...
I have the update..
Hate the 7at... blah
With that said though. Hot days obviously don't play nice for our engines. or any for that matter.. cold air being sucked in vs hot air makes a huge difference.
with you having humidity I'm guessing that adds to it as well. not very humid here ever.
Old Aug 10, 2015 | 08:45 AM
  #38
djdiskino's Avatar
djdiskino
Exactly @mezzo it holds onto gears then ultimately drops to the lower gear with a jerky feeling.
I did clean my throttle bodies last night I was shocked there was any build up in them or maybe I didn't clean them as thoroughly as I thought the first time. I did disconnect the battery when I did this so I'll give it a few weeks to see if it's just that but the shifting is nice and smooth again.
I was thinking that smoothing out the acceleration and idle will help with the car adjusting the engine speed to match the automatic shifting so it's not so rough (makes sense in my head)
Old Aug 11, 2015 | 03:04 PM
  #39
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
make sure you do the throttle body reset set it help out major..i did it a few times.. if you follow the guy in the video it works everytime..read the description first then follow along
misc
29
May 24, 2023 03:57 PM
Slapshot1
Sep 27, 2015 08:40 AM
Allboutcali
Sep 26, 2015 03:43 PM
ben-g37s
Sep 22, 2015 01:36 PM
