TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
tps problem (throttle position sensor)
Old Nov 14, 2010 | 08:17 PM
blacky g37's Avatar
blacky g37
i had some problem when i start up the car the rpm drops down to nearly 200 and sometimes it reaches 0 and the car shuts down i took it to a diag check and it showed the codes: p1815 manu mode sw circ and p1705 tp sen/circ A/T what are those codes and whats the problem do i need to change the sensors ? please help
Old Nov 19, 2010 | 10:25 PM
blacky g37's Avatar
blacky g37
anyone help with this
Old Nov 21, 2010 | 10:18 AM
myk1013's Avatar
myk1013
Have you checked your intake sensors. One side might be loose or disconnected.
Old Nov 21, 2010 | 05:56 PM
blacky g37's Avatar
blacky g37
its fine if the the sensor is loose i think the cel will show
Old Dec 22, 2010 | 07:47 PM
ifinity's Avatar
ifinity
Although you probably have had this problem fixed by now, the 2008 service manual page TM-143:
"p1705 is Description INFOID:0000000001672165
Electric throttle control actuator consists of throttle control motor, accelerator pedal position sensor, throttle
position sensor, etc. The actuator transmits a signal to the ECM, and ECM transmits signals to TCM with CAN
communication.
DTC Logic INFOID:0000000001672166
DTC DETECTION LOGIC
DTC CONFIRMATION PROCEDURE
NOTE:
If “DTC CONFIRMATION PROCEDURE” has been previously performed, always turn ignition switch
OFF. Then wait at least 10 seconds before performing the next test.
1.CHECK DTC DETECTION
With CONSULT-III
1. Start the engine and let it idle for 1 second.
2. Perform “SELF-DIAG RESULTS” mode for “TRANSMISSION”.
Is “P1705 TP SEN/CIRC A/T” detected?
YES >> Go to TM-143, "Diagnosis Procedure".
NO >> Check intermittent incident. Refer to GI-38, "Intermittent Incident".
Diagnosis Procedure INFOID:0000000001672167
1.CHECK DTC OF ECM
With CONSULT-III
1. Turn ignition switch ON.
2. Perform “SELF-DIAG RESULTS” mode for “ENGINE”.
Is any DTC detected?
YES >> GO TO 2.
NO >> Check DTC detected item. Refer to EC-120, "CONSULT-III Function".
2.CHECK DTC OF TCM
With CONSULT-III
YES >> GO TO 3.
NO >> Check DTC detected item. Refer to TM-112, "CONSULT-III Function (TRANSMISSION)".
3.CHECK TCM POWER SUPPLY AND GROUND CIRCUIT
Check TCM power supply and ground circuit. Refer to TM-163, "Diagnosis Procedure".
Is the inspection result normal?
YES >> Replace the control valve with TCM. Refer to TM-232, "Exploded View".
NO >> Repair or replace damaged parts."
p1815 was in another tsb topic about manual mode switch malfunction for going between D and DS.
Amaadkhan2k
Oct 4, 2024 01:20 PM
jgronline
Sep 21, 2015 08:44 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
ZachThomas
Sep 3, 2015 01:40 PM
