The FX-Spot General discussion for the FX35/FX45
FX Rear Camber and Toe Kits
Old Jul 20, 2007 | 09:21 PM
rookie's Avatar
rookie
Widebody what?!?!
With the help of some of the G35 drivers. We tried to see what parts from the G35 would fit on the FX.
The off the shelf SPC toe bolt kit fits right up.
Here's side by side comparison of the toe adjustment bolts. Left is oem right is SPC.
Another angle.
Pic of the difference in the cam washers.
Now when we got to the camber bolt, notched the sub-frame and slid the bolt in. It came up a little short. The FX sub-frame at the camber point is about 1/2" thicker than the G/Z. Wanting to have enough threads we just put the stock one back in and set out on getting longer bolts.
Here's the FX sub-frame, red is camber point black is toe point.
Comparison on the bolts.
Stock toe bolt at top, SPC toe bolt below it, 100mm bolt that needs machining, 100mm bolt with the SPC nut to verify the rest of the hardware was going to work.
FX toe point with the SPC kit installed.
FX camber point
Closer
FX camber point with the longer bolt and SPC washer and nut installed.
Hopefully that helps someone out there.
SBG37
May 5, 2022 10:35 AM
Majeed Bader
Oct 8, 2015 10:52 AM
Majeed Bader
Sep 4, 2015 01:55 PM
Ipp391
Aug 28, 2015 09:27 AM
