Upgrade Vortech Coupe-Progress Thread
Old May 31, 2007 | 04:33 PM
  #121
venommaxr33's Avatar
venommaxr33
i think we should do a catch can on both your cars. im going to do it on mine b/c i have a problem with oil in the plenum. you can make you own which is pretty easy or just buy one. just an idea!!!
Old May 31, 2007 | 04:34 PM
  #122
venommaxr33
Originally Posted by G Thizzle
LOL...no you inpatient woman... I am going to pull the cats off and go with Robs fast intentions test pipes... i think i fried both cats so time to take them beeeaches off!
hooters
Old May 31, 2007 | 04:48 PM
  #123
SKYLINE_GT's Avatar
SKYLINE_GT
Hot, nasty, bad-a** speed
How are you planning on making one, I have always wanted to do one, just dont want to spend all that money..
Old May 31, 2007 | 05:23 PM
  #124
venommaxr33
i found a write up here on the forum, i'll print it and bring it tonight. i just bid on a greddy catch can on ebay for $30 and $12 shipping. real simple to make. you can get the stuff at home depot!!!!
Hey D, by the way i found injectors on ebay for $529 not sure if you got your bigger injectors yet but these are 750cc!!!!
Old May 31, 2007 | 05:26 PM
  #125
venommaxr33
here's the link to the page.
http://g35driver.com/forums/showthre...=oil+catch+can
Old Jun 1, 2007 | 12:44 AM
  #126
Blackbird V35's Avatar
Blackbird V35
FYI, i just did the exact same install you just did and its not the stock FPR you are drilling, its the siphon jet. its the little yellow piece on the bottom fuel pump assembly. If you have a fuel return system you shouldnt even have the FPR in the fuel pump assembly, the kit should have came with a bypass
Old Jun 1, 2007 | 01:36 AM
  #127
SKYLINE_GT's Avatar
SKYLINE_GT
^^The little yellow piece at the bottom of the sending unit, isnt that just a yellow cap piece. It doesnt really connect to anything. And you do have to drill the intank regulator, to make the jet bigger.
Old Jun 1, 2007 | 01:53 AM
  #128
SKYLINE_GT's Avatar
SKYLINE_GT
Update:
Car is running good AFR at idle is around 9 and when i give it gas it goes up to about 11~12. I noticed oil leaking on the floor just behind the pan. So put it on the lift and couldnt really tell where it wa coming from so just pulled the whole pan and spacer and resealed it with more gasket sealant. hopefully that fixed it. Should be back up at the shop on saturday.
Old Jun 2, 2007 | 01:43 AM
  #129
Blackbird V35
no its actually called a siphon jet, if you look in the CJM install manual for the return fuel system it tells you to drill it out to .070" If you pop it off (I had to do it with a long screwdriver from the inside of the plastic assembly) you will see that there is a very small hole in it. If you have a return system you should have completely bypassed the intank regulator, hence the need for a aeromotive FPR.
check it out here
http://www.cj-motorsports.com/s1install.htm
Old Jun 2, 2007 | 11:52 AM
  #130
SKYLINE_GT's Avatar
SKYLINE_GT
^He is not using a Return kit.
Old Jun 5, 2007 | 12:29 PM
  #131
SKYLINE_GT's Avatar
SKYLINE_GT
Looks like drew is going to be towing his car to SGP as i drive real slow in mine. Also couldn't get re scheduled till next wednesday. Right now im trying to hook up a PDA to the Utec to see if I can log it from there.
Old Jun 15, 2007 | 07:17 PM
  #132
SKYLINE_GT's Avatar
SKYLINE_GT
Well all our hard work was finally paid off. Here is a vid, enjoy. Will be going back in about two weeks. Going to tweak the car a little and get a retune. Heatsoak killed me!!! It was so HOT!
Dynoed - 350whp & 315 wtq But still in the hunt for 400whp
Old Jun 15, 2007 | 07:25 PM
  #133
SKYLINE_GT's Avatar
SKYLINE_GT
4:00 In the morning
On the Dyno
The shinyness
Old Jun 15, 2007 | 09:24 PM
  #134
venommaxr33
looking good D!!!
  #135
G Thizzle's Avatar
G Thizzle
$up3rch@rg3d Vq35
clean that engine bay...LOL... ohhh i likey... man now i gotta post my pics and vids!!! here they come!
