Supporting Vendors Products and services, available for purchase from registered vendors.
What everyones been waiting for!!! BC Racing Coilovers!!!!
Old Apr 15, 2008 | 03:40 PM
  #196
1BADV6's Avatar
1BADV6
Coilovers ordered...thanks BG!
Old Apr 15, 2008 | 03:58 PM
  #197
Black Guy's Avatar
Black Guy
No problem sir, hope we can take care of your further G37 needs
Old Apr 15, 2008 | 04:07 PM
  #198
Kidcane's Avatar
Kidcane
Florida G Club
Originally Posted by IP37
anybody know the proper way to adjust the front?
after goofing around with it, i'm guessing I need to unbolt the strut from the bottom and spin the bottom part of it up?
trying to lower the front about 2" lower than it was
Fronts are easier than the rear. Just unbolt them at the bottom, use the wrench to tighten (if you are lowering) the travel distance. Then bolt back up.
Old Apr 15, 2008 | 04:58 PM
  #199
IP37's Avatar
IP37
Take the small wrench and loosen the bottom... then turn the top... it goes down real slow... and it can squeek sometimes but keep turning...
sure about that? that loosens up the spring doesn't it?
i unbolted the strut from the bottom / endlink and just spun the bottom up. that seemed to make the most sense to me.. it didn't adjust the tension on the spring or anything
i could be wrong though
and on the rear i ended up putting the spring in with the collars on top, used the oem bottom rubber piece, and took out the oem top spring perch.. it seemed to make the most sense to me because the collars would be easier to get to, the writing on the springs went that way, and the top perch has three little prongs under it that hold it up, and they went perfectly into the (top?) piece from bc
Old Apr 15, 2008 | 05:22 PM
  #200
symalik's Avatar
symalik
I wouldn't do what max is saying because then you are adjusting the spring tension and the ride height. I did what you said earlier, unbolt the bottom, and spin that up to lower it.
For the rear, from what I understand, you have to take the springs out to adjust the height. I guess it shouldn't really matter where you put the perch on top or below the springs because each way it has equal pressure on it. I did my rears opposite of yours, left the stock top rubber piece in and put the BC perch under the spring. I adjusted the height before I put them on, and its even on both sides... i just measured it very closely lol.
Old Apr 15, 2008 | 05:26 PM
  #201
IP37's Avatar
IP37
cool, that's what i did on the front. actually lowered it a little more than i wanted, so i'll be back at it again tomorrow. right now it's pretty much the same height in the front as it was with the h&r springs
and i haven't adjust the rear yet, another task for tomorrow
Old Apr 15, 2008 | 05:53 PM
  #202
TerribleONE453's Avatar
TerribleONE453
think im ordering tomorrow..
Old Apr 15, 2008 | 05:54 PM
  #203
IP37's Avatar
IP37
go for it
Old Apr 15, 2008 | 05:55 PM
  #204
symalik's Avatar
symalik
You think I should change my rear or just leave it as is? I guess I can wait for actual instructions from pete or look at max's pictures when he posts them.
Old Apr 15, 2008 | 05:56 PM
  #205
TerribleONE453
well max already has me convinced... just dont want something coming out that will be much better really soon...
Old Apr 15, 2008 | 05:58 PM
  #206
IP37's Avatar
IP37
i'm not 100% sure which is the right way, but the way i put mine on seemed to make a little more sense to me than doing it the other way
i'd wait for pete to answer
i was like you though.. when i first went to put them on i was going to do it the way you did.
anyone put the rears on with the collars under the spring without adjusting them first? i'm wondering what the drop looks like that way.. i thought mine was going to be lower than it is, since i took out that spring perch. but it's higher that the h&r springs were
Old Apr 15, 2008 | 06:58 PM
  #207
IP37's Avatar
IP37
lol and crap.. the rear shocks are the same way on the bottom...
should they be adjusted the same amount the rear spring is adjusted or something?
Old Apr 15, 2008 | 10:17 PM
  #208
symalik's Avatar
symalik
nah, i just lowered the rear shocks to match the stock shock height before i put it on.
Old Apr 15, 2008 | 10:22 PM
  #209
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Wow I came out from work today and the rears and settle a half an inch... and to spend the evening raising the rear... I didnt get to write up my review yet... im goin to start now...
Old Apr 15, 2008 | 11:00 PM
  #210
Kidcane's Avatar
Kidcane
Florida G Club
^^Pretty much what I had to do.
