Supporting Vendors Products and services, available for purchase from registered vendors.
What everyones been waiting for!!! BC Racing Coilovers!!!!
Old Apr 16, 2008 | 01:01 PM
  #226
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
it comes to with new rubber thingamabobers....
Old Apr 16, 2008 | 02:47 PM
  #227
IP37's Avatar
IP37
mine didn't?
not for the bottom..
i reused the old bottom piece.
got my front where i want them, started playing with the rear.... measurements on the spring / shock match.. but for some reason the passenger side is like 1/2" higher. just have to figure that out now
Old Apr 16, 2008 | 04:23 PM
  #228
symalik's Avatar
symalik
I guess I will flip the rear springs this weekend and just use the rubber stock bottoms since I really don't want the metal/metal contact.
And some how fix the noise coming from the fronts.... No idea what it could be how how my rotor/caliper got misaligned but something sure did happen
Hopefully maybe look at it tonight.
Old Apr 16, 2008 | 04:59 PM
  #229
MaxToTheG37
Well I seen 2 rubber things at least... maybe they were for the fronts...
If I need to take some more pics for a detail let me know
Old Apr 16, 2008 | 05:13 PM
  #230
symalik's Avatar
symalik
Can you please take some pics of the rear spring? Top and bottom, that would be great!
I am sure I got the front coilover install right, just driver side rotor might be misaligned? Who knows, will take off the wheel when I get home and check.
Old Apr 16, 2008 | 05:19 PM
  #231
IP37's Avatar
IP37
on the rear the top spring perch comes out.. it's a cone shaped rubber piece, just pulls right off.. three little prongs hold it on
and i reused the bottom rubber pieces
Old Apr 16, 2008 | 05:30 PM
  #232
symalik's Avatar
symalik
So real quick again, I understand how to fix the rear now but for the front when you have your car jacked up and you spin the wheel, does it make a light sound of pad rubbing on rotor? At all? Ive always had this on my car just not sure if its normal or not.
Old Apr 16, 2008 | 07:39 PM
  #233
Black Guy's Avatar
Black Guy
2 of our lucky firsts, on this shipment.
1. 1BADV6
2 13adz06
Shipment recieved, they're ready to go!!!! Order now and receive them in just a few days! Get them before they all disappear!!! Shoot me a PM
Old Apr 16, 2008 | 08:08 PM
  #234
TerribleONE453's Avatar
TerribleONE453
i think my name is gonna be up soon...
Old Apr 16, 2008 | 08:12 PM
  #235
Black Guy's Avatar
Black Guy
Why wait?
Old Apr 16, 2008 | 08:14 PM
  #236
TerribleONE453
cause im being cheap... lol
Old Apr 16, 2008 | 08:17 PM
  #237
Black Guy's Avatar
Black Guy
Down grade to a G35 then
Hahaha jk jk
Old Apr 16, 2008 | 09:07 PM
  #238
1BADV6's Avatar
1BADV6
Will you be emailing my tracking numbers? Thanks BG.
Old Apr 16, 2008 | 09:52 PM
  #239
IP37's Avatar
IP37
sure it's actually the pads on the rotor? see if you can slide a sheet of paper or something between them and then spin the rotor
Old Apr 16, 2008 | 10:57 PM
  #240
symalik's Avatar
symalik
I got it, it was the plate behind the rotors, I bent it kinda when i was manually turning the wheels so it was rubbing on the back a bit. All fixed now, thanks for the help.
