G37 & 07+ SEDAN Key Hole Cover (ESCUTCHEON)!
Factory INFINITI Part for your G37 & 07+ Sedan!
Clean up the look of your car with these Factory Painted Drivers Side Door Lock Key Hole Delete Finisher Panels!
G37 Driver Side
A54 - Vibrant Red
B21 - Athens Blue
K23 - Liquid Platinum
K51 - Platinum Graphite
K52 - Blue Slate
K57 - Amethyst Graphite
KH3 - Black Obsidian
QX1 - Ivory Pearl
QAA - Moonlight White
V36 Sedan (2nd Gen)
A54 - Vibrant Red
B21 - Athens Blue
B30 - Lakeshore Slate
K52 - Blue Slate
QX1 - Ivory Pearl
HAA - Sahara Sandstone
US shipped out of CA: $32.95
US shipped in CA: $32.95 plus tax
PayPal request is an additional 3% on the price
If you would like to purchase using PayPal PM me your paypal email address and shipping zip code.
If you would like to pay via credit card, give me a call at 800-919-8130 / 951-324-8282 ext.229
For a faster response call us direct at 800-919-8130 or 951-324-8282
G37 Driver Side
A54 - Vibrant Red
B21 - Athens Blue
K52 - Blue Slate
QX1 - Ivory Pearl
V36 Sedan (2nd Gen)
A54 - Vibrant Red
B21 - Athens Blue
K52 - Blue Slate
QX1 - Ivory Pearl
Install is pretty easy, there are a few ways to do it.
Thanks to our fellow G35Driver.com members for the quick write ups on the DIY and for doing the research.
Originally Posted by terrycs
*I take ZERO responsibility if you **** up your car following these directions*
Lock your door.
Pull the door handle as if you were going to open it, then put a rolled up towel in-between the handle and the door to keep it open.
Then using the pic below as reference, use a small flathead screwdriver or what ever you have that is able to get into the space to lift the tab up. As you are lifting the tab, pull on the cover to remove it.
When you receive the part it comes attached to the mounting plate. See pic below. You are going to have to follow the same procedure to remove it from the mounting plate as you will when you take it off the car. This will give you an understanding of what you need to do on the car to remove it.
Lock your door.
Originally Posted by kmuniz78
SWEET! Thanks!
Instructions for removing driver's side keyhole cover; Give a real clean look:
1st - Locate the black cap on the inside of the driver's door (see pic)
Attachment 92497
2nd - Pop off cap; locate hex screw; difficult I know:
Attachment 92498
3rd - Use 5/32" hex rench to unscrew bolt (won't fall into door; has a saftey lip)
Attachment 92499
4th - Pop off keyhole cover (forgot to take pic); replace with new cover (also forgot to take pic)! Should look like this when done:
Attachment 92500
Attachment 92497
Attachment 92498
Attachment 92499
Attachment 92500
Not that its that big a deal but you can get it here http://www.g35parts.com/9083/osc/pro...roducts_id=755
for 21.80 plus shipping, im sure shipping can't be more then 5.00
^^Doing what we do here it is one of my jobs to shop the competition and believe me the price of the cover and shipping will run $39.00 from them, check it for yourself.
Honestly for the extra 2 dollars I would have had no problem ordering from you, I love to support the vendors on the site and I have picked up some stuff for my G35 from you.
My dealer quoted me 52.00 for it. So either way, great price.
If you want a real shipping rip off, order a spoiler from grubbs. My shipping was 48 dollars
Hey Rick, I was just brousing your site.
You have the OEM spoiler listed for 392.18. Is this correct??? That is hella cheap. If that is right, I need to cancel my order with grubbs immediately.
