Southern California San Diego, Los Angeles, Orange County, Inland Empire, etc.
Place that removes emblems
Old Jan 2, 2014 | 02:43 PM
krovon731's Avatar
krovon731
Hey all,
I was just wondering if any of you know a good shop somewhere in Socal (preferably 949 area) that can help me remove that "Infiniti" emblem on the trunk for me because I am unable to do it myself properly. I'm just afraid I might mess up lol. Thanks a lot!
Old Jan 2, 2014 | 03:42 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by krovon731
Hey all, I was just wondering if any of you know a good shop somewhere in Socal (preferably 949 area) that can help me remove that "Infiniti" emblem on the trunk for me because I am unable to do it myself properly. I'm just afraid I might mess up lol. Thanks a lot!
Your garage! Just go get some goo gone, some dental floss, a few old tshirts and some scratch X remover.
Dribble some goo gone behind the letter and let it soak for a minute or two, catch the runoff with a rag. Use the dental floss to slice behind the letter and "cut" through the adhesive which should be loose by now. Repeat for all the letters. Wet a clean tshirt rag with more goo gone and scrub the leftover adhesive residue (I had a lot still stuck to the car), until it's all clean. Then follow the instructions on the scratch X remover to clean up the sun faded area! Takes one hour tops.
Old Jan 2, 2014 | 03:44 PM
GoFightNguyen
Because Racecar
No heat needed in my case, it probably helps though. Oh, and wear gloves when messing with the goo gone. A little goes a long way, and make sure you catch the runoff. It never hurts to wash the car afterwards to ensure you got every last splatter off.
Old Jan 2, 2014 | 03:55 PM
Darth Kinetic's Avatar
Darth Kinetic
heat gun and a soft plastic wedge or tool,
goo gone for whats left.
wash and wax
Old Jan 2, 2014 | 07:12 PM
John B's Avatar
John B
I didn't used heat either, after the letters left residue I used a credit card to oral off the rest and washed and waxed it an it looks great!!!
Old Jan 2, 2014 | 07:54 PM
riffraff's Avatar
riffraff
usually body shops will do it. I'm in the 949 and I've gone to precision auto body in MV. took off n put mine on a couple of times
Old Jan 2, 2014 | 08:11 PM
Darth Kinetic
you dont need a lot of heat, even a hot SoCal day in the sun will get your emblems soft for removal
Old Jan 2, 2014 | 08:12 PM
yrag's Avatar
yrag
My friend uses boiling water and a metro card then we rebuffed the area
Old Jan 2, 2014 | 10:54 PM
bluedevils95's Avatar
bluedevils95
I just pulled it off in the sun, then i had the trunk sitting in up and let the WD-40 soaked in and then wiped everything off. Came out pretty clean for me.
Old Jan 3, 2014 | 05:16 PM
Flores45's Avatar
Flores45
This is probably the easiest and cheapest thing you can do!! Paying a shop to do this would be just dumb.
Old Jan 3, 2014 | 05:44 PM
TVPostSound's Avatar
TVPostSound
Now that the Q60 has the dumb 3.7 emblem behind the front wheel, everyone will be removing emblems!!
Old Jan 3, 2014 | 07:06 PM
riffraff's Avatar
riffraff
i hear people take off emblems using fishing line
Old Jan 26, 2014 | 12:27 PM
Sergio Soto's Avatar
Sergio Soto
hello i work for Warren Henry Infiniti in Miami
My detail department uses a plastic razor blade or dental floss to remove the letters
mineral spirits to remove the glue
and some compound and wax afterwards
not worth paying somebody to do this, its an easy DIY
Old Jan 26, 2014 | 10:29 PM
G37jeff's Avatar
G37jeff
Friend of mine took a blow dryer to his trunk emblem and it popped off
Old Jan 27, 2014 | 08:20 AM
Vizard_87's Avatar
Vizard_87
Maybe this video can help you do it yourself and maybe save some money.
cconklin2
Jan 9, 2016 07:21 PM
bigmike35nj
Sep 22, 2015 12:49 PM
philttz
Sep 21, 2015 11:12 AM
VIVID
Sep 14, 2015 03:31 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
