Site Feedback & Suggestions For posting feedback and suggestions regarding MyG37.com
2013 Coupe Speaker Grill
Old Apr 21, 2014 | 07:30 PM
redbankcharlie's Avatar
redbankcharlie
Duhh! I accidentally kicked a hole in the driver side door Bose speaker grill.
Is it true that the whole door panel has to come off?
Can someone please post instructions for that?
Aso, where's the best place to buy a replacement grill?
Thanks
Old Apr 21, 2014 | 08:21 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by redbankcharlie
Duhh! I accidentally kicked a hole in the driver side door Bose speaker grill. Is it true that the whole door panel has to come off? Can someone please post instructions for that? Aso, where's the best place to buy a replacement grill? Thanks
Yep, the door has to come off. Never fear though, a 14mm socket and a screwdriver set are all you need. I'm on my phone now, but I will post the instructions when I get home tonight.
I did something similar and bought my replacement speaker grille from Infinitipartsusa.com
It shouldn't be more than 40 bucks, and 20 minutes to replace it.
Old Apr 21, 2014 | 09:07 PM
redbankcharlie
Thanks so much. I look forward to the instructions.
Can you also teach me how NOT to put my foot through it again?...LOL
Old Apr 21, 2014 | 10:08 PM
GoFightNguyen
Because Racecar
Can't really help you there, my speaker grille was smashed out when something heavy in the passenger seat flew forwards as I braked to avoid a collision.
Here's the part you're looking for, it should be item 4, just choose "left" side, and make sure it's the correct color.
2013 Infiniti G37 Sport Interior Trim
As far as instructions, please refer to the service manual, available here:
http://www.nicoclub.com/FSM/G37/Coupe/2012/INT.pdf
Please refer to page 12, Int-12. It will detail how you remove the bolt covers, remove the bolts, and pop the door finisher off the metal door frame. You'll then disconnect the wiring harnesses (optional, but easier for you), then unscrew the broken speaker grille and install the new one (phillips screws). While you're in there, it's not a bad idea to check your speaker and make sure it wasn't damaged.
Cheers
Old Apr 21, 2014 | 10:09 PM
GoFightNguyen
Because Racecar
If you plan on making it a habit, it's worthwhile to invest in a 20 dollar trim removal tool set. I use it just about every time I work on my car and it has prevented SO many scratches that I would have caused had I just wrapped a flathead screwdriver in tape.
Astro Pneumatic 4524 Auto Fastener and Molding Removal Tool Set, 11-Piece - Air Tool Maintenance Kits - Amazon.com Astro Pneumatic 4524 Auto Fastener and Molding Removal Tool Set, 11-Piece - Air Tool Maintenance Kits - Amazon.com
Old Apr 21, 2014 | 10:24 PM
redbankcharlie
By the way, I've got a 2013 G37XS if that makes a difference
Old Apr 21, 2014 | 10:26 PM
GoFightNguyen
Because Racecar
Makes no difference, I don't think. Put your specific model in and check.
superjoey
31
Mar 22, 2023 11:56 PM
jaylock92
Apr 22, 2022 12:39 PM
sharmelan
Aug 25, 2015 03:41 PM
