New Owner - 2010 G37xS Maintenance Tips
Old May 10, 2023 | 11:13 AM
DannyP's Avatar
DannyP
Question New Owner - 2010 G37xS Maintenance Tips
New owner of a 2010 G37xS Sedan 7AT. Still has the original motor with about 270,000 KM's on it the previous owner was a foreman at Infiniti so the car was taken care of. With that being said and the G having high mileage i'm looking for preventative maintenance & tips to sustain the G and keep it running strong as it is now my daily.
In my short possession the vehicle has been fully detailed, new D2S bulbs, power steering has been flushed & refilled, Y-Pipe replaced due to wear & tear, Oil change (Amsoil) + New filter, summer tires swapped.
Plan to Change: All fluids remaining like Brake fluid, coolant, auto trans fluid, transmission, transfer case, and both front and rear differential fluid.
1 Ballast to be replaced just went out, AC amplifier as fuel gauge incorrect.
New spark plugs, ignition coil packs, ignition boot.
Engine, Fuel, and Cabin filters to be replaced.
Clean Throttle Body + MAF Sensor, New TB gasket
Idle + ECU relearn, Fuel system cleaning
Hoses/Belts?
For Fluids i'm uncertain some say stick with OEM fluids and some say Amsoil or suggest other brands. What's the best fluids for our car?
Looking to take care of this car & keep it for as long as I can. Went from a 6SPD RWD Turbo Coupe to my first 4DR Sedan and I love it. OCD when it comes to cars and maintenance. Fellow G owners please chime in and share your knowledge!
Old May 14, 2023 | 06:59 AM
zoe infinity's Avatar
zoe infinity
Welcome to the forum
Old May 15, 2023 | 07:37 AM
Sea Stories's Avatar
Sea Stories
Welcome. Maybe add PCV valves to your list. One of mine was stuck when I replaced mine at 98,000 miles.
Sea Stories
Old May 15, 2023 | 01:23 PM
socketz67's Avatar
socketz67
Community Builder
2nd PCV vales. Easy update that mysteriously does not show up on the scheduled maint.
Add upper and lower radiator hoses, radiator cap, thermostat and replace the plastic heater hose coupling on the passenger side. Maybe check the suspension as well? Struts, shocks, endlinks, rear diff bushing?
Z1 Motorsports is a great source of OEM parts that are lower cost compared to the dealer.
I personally wouldn't mess with the ignition coil packs unless they are damaged (will throw a code if they are). Similar for the fuel filter as I have never heard of anyone replacing it on their G37.
Another thing that goes out in time is the analog clock LED. I drove for a year with it out and never knew. Then I saw someone here talk about replacing it....I bought one from a salvage yard and the dash looks much better with the LED working.
Old May 27, 2023 | 02:58 PM
2012G37xsSedan's Avatar
2012G37xsSedan
Heater hose coupling
I definitely agree with heater house coupling, mine recently totally failed. It’s a plastic that was able to be broken into bits with my fingers after 120k miles.
VQpoppa
Apr 9, 2016 12:55 PM
Farrockaway5c
Feb 17, 2014 06:18 PM
stiizy
Jan 16, 2014 02:30 PM
JJSoCrazy
Mar 3, 2010 04:24 PM
marano
Apr 17, 2009 02:30 PM
