High Mileage oil recommendations
Old Mar 2, 2023 | 06:32 PM
bread's Avatar
bread
Sorry. It's a quote from Alice in Wonderland. The whole what oil to use is an often heated topic that takes one down the proverbial rabbit hole, so I thought it was fitting. If you google "G37 0W40 recommendation", there are several threads on the topic.
Here's a thread that discusses 0W40 vs 5W30 in some detail (justification seems to center around the base oils used): https://www.myg37.com/forums/engine-...-concerns.html
Originally Posted by PDG
I take it to mean the oil rabbit hole is like Alice in Wonderland. You can easily get lost there. Ask me how I know.
The theory behind M1 0W-40 is it is a thin 40 weight (13.8 KV), so not much thicker than the top end of 30 weight oils (they end at 12.5 KV), but has a higher HTHS value (High Temp / High Shear) and thus holds up much better to the high temps that VQ37VHR engines create.
just seems odd that you are completely changing the viscosity rate. even if it "close", its literally a whole different genre of specification.
im going to stick on my safe side and keep using RP high mileage 5w-30
Old Mar 2, 2023 | 06:37 PM
PDG's Avatar
PDG
Absolutely nothing wrong with that .
Again, any oil that meets the required spec in the manual (SM, IIRC) and is changed on time will be fine.
Old Mar 2, 2023 | 06:38 PM
bread's Avatar
bread
i have switched over to royal purples high mileage formula after i found out it existed, im super soaked for it, for its insane cleaning properties and ofc the high mileage additives, running 170k n counting miles
Old Mar 2, 2023 | 07:11 PM
thescreensavers's Avatar
thescreensavers
​​​​​As long as you are using a quality oil and it's full you'll probably will never see an oil related failure. Our motors oil temps are not bad until you start beating on it.
there are better choices if you beat on your car or track it reaching higher oil temps. With higher oil temps it's recommended to go up a grade for protection, its fairly common.
​​​​0W40 M1 FS(euro) is an excellent oil and has a lot of factory approvals and at the cost is an amazing value which is why it's recommended a lot.
I'm personally running on Valvoline 5W40 MST cause I bought 100 quarts stupid cheap years ago so got to use it up . I redline every chance I get
Old Mar 2, 2023 | 07:14 PM
bread's Avatar
bread
ended up getting the RP HM for about $37.99/jug on jegs with coupon and free shipping. So im pretty happy about that, ik that RP has some great cleaning properties for your upper crank area, ive noticed that MB1 has gone down in its quality, as there has been numerous tests done showing the lack of additives and detergents unlike some of the other leading brands. maybe the 0w40 is different because of its "minimum requirements" under euro spec, but still
DenisTheMenace
Oct 15, 2013 10:52 PM
ak_g37
Jan 25, 2012 01:21 PM
