G37x Coupe Handling Issues
Old Mar 16, 2018 | 05:57 PM
Sciroccojay's Avatar
Sciroccojay
I have a 2012 G37x coupe with 58,000 miles. Overall the car is in pretty good shape inside and out. Over the last 2000 miles or so the car has progressively gotten worse with handling at highway speed’s. It’s moving side to side and I’m constantly correcting it to stay in the lane.
I have brought it back to the dealer and to another mechanic. They both check the alignment, suspension,tires(new) and all linkage and say everything is fine.
Is anyone else experienced this and if so did you fix it? I am open to any and all advice.
Old Mar 16, 2018 | 06:18 PM
slartibartfast's Avatar
slartibartfast
Welcome. I suspect either tire issues or wearing steering gear. I rarely hear of steering parts wearing at your mileage, though.
Swap the tires front to back and see if that changes anything.
Old Mar 16, 2018 | 07:07 PM
Sciroccojay
Thank you for your reply. I changed tires thinking the same exact thing. News tires with only about 500 miles on them now.
Old Mar 16, 2018 | 10:49 PM
What tires are they? Some tires are more prone to tramlining, and this may be something you're experiencing if it's gotten worse since your new tire purchase. Do you have your latest alignment sheet, low caster can cause a wandering feel, good to know what specs you're currently at.
Welcome to the site btw.
Old Mar 16, 2018 | 11:22 PM
Sciroccojay
right now I have cooper cs5. The old ones were some dunlops I cant remember the name of. It is about the same with the new tires. One of the mechanics said this could be a trailing arms issue since pretty much everything has been checked out and said to be ok.
Old Mar 17, 2018 | 08:56 AM
Sciroccojay
Old Mar 17, 2018 | 09:03 AM
Looks like a good alignment, caster is low but just in spec. Not sure if there's a way to get more caster w/ OEM parts (I have high caster adjusted w/ aftermarket arms), if there is a way to get the caster closer to 5 w/ your OEM setup I'd consider that.
Old Mar 18, 2018 | 07:55 PM
NealP's Avatar
NealP
Any chance there’s an issue with one of the rims? I would assume they’d catch it but you never know. Have you asked them to road force balance the tires?
Old Mar 19, 2018 | 07:29 AM
Sciroccojay
i havent but to be honest ive been thinking that maybe a rim is bent or something. I thought maybe they could see that when they mounted and balanced the tires but possibly not right?
Old Mar 19, 2018 | 10:21 AM
hockeyzbh's Avatar
hockeyzbh
following for info. got the same issue on my 09 g37x coupe. My wheels also shudders at high speeds tho. I have been worried I have a bent rim but not sure really. I have really durable tires tho (continental extreme contacts brand new) so not sure the issue. I recently had my alignment done and it helped a little but car still sways weirdly. Mine is lowered on bc coils tho without a camber kit or aftermarket arms so my issue may be related to that
Old Mar 19, 2018 | 01:47 PM
NealP's Avatar
NealP
It might be a small enough bend that it's not visibly noticeable but still effects the car. I had a similar issue and went to a couple dealers and they found nothing. They kept saying it was because of the "crown of the road" but I was able to duplicate it on a flat surface or on a highway where in the left lane if anything it should veer left but mine would veer right. They rotated the wheels to see if it would now veer left but it didn't make a difference. One dealer suggested grabbing a wheel (or all 4) from another G and see if the problem went away but they didn't have one at the time.
I decided to wait until I got new tires. The problem never fully went away with two different sets (summers and winters) but did get drastically better after a road force balance and alignment (I vaguely remember the service advisor mention new alignment specs) to the point where I hardly notice it unless I'm focusing on it plus I'm not on 100% stock suspension anymore so the dealer probably wouldn't help me anyway.
Badgerman
May 2, 2013 03:30 PM
KrnMackMattsta
Feb 8, 2012 11:49 AM
EVO-to-G
Oct 29, 2008 11:34 PM
LudwigB
Oct 3, 2008 09:33 PM
