G37x 2009 suspension change
Old Aug 26, 2017 | 10:27 AM
PHX's Avatar
PHX
Looking for a good diy thread on struts/shock replacement.
Any suggestions?
Old Aug 26, 2017 | 11:06 AM
Here's a DIY on changing to lowering springs but most of the steps will apply for just keeping your OEM spring set. This is for a RWD, the front lower mounts on your AWD will be different, might have to check the FSM for specifics there as far as torque and any additional fasteners involved.
https://www.myg37.com/forums/d-i-y-i...g-install.html
Here's the Front suspension FSM (AWD starts on pg.25)
Factory Service Manuals - NICO Club
And Rear
Old Aug 26, 2017 | 11:12 AM
PHX's Avatar
PHX
Thank you blnewt!
Old Aug 26, 2017 | 11:23 AM
No problem, if you DIY this and reuse your OEM springs on your new front shocks PLEASE avoid the Harbor Freight spring compressors, we prefer to have our members stay alive
Old Dec 20, 2017 | 01:22 PM
PHX's Avatar
PHX
Forgot to ask. Are konico blue compatible with x models? What are most people replacing the oem with?
Old Dec 20, 2017 | 02:42 PM
X is VERY limited to shocks, I believe OEM is your only option there unless you go w/ all new coilover set.
