2008 G37s headlight questions.
Old Apr 16, 2015 | 07:00 PM
jorgeb1024's Avatar
jorgeb1024
hi guys, im very new here, and i tried searching but didnt find the answer anywhere -_-
i have a 2008 g37s coupe with navi.
my regular headlights are working fine,
but i noticed that when i turn my headlight switch 1 click to "auto"
there's a small amber bulb that turns on, on my right headlight, in the inner area of the assembly, the outer being the normal headlights. the small amber lights isnt very bright, then when i turn the **** 2 clicks for the normal headlights, the small amber light stays on still. but only on the right side.
on my left headlight, the amber buld isnt turning on. what is this bulb called, so i can replace it?
also, above the amber bulbs, are another set of bulbs, i thought these were the high beams, but after i turned the high beams on, the high beams are on the outer section, same as the regular beam.
1. what are the small amber bulbs?
2. what are the bulbs above the amber bulbs, and why arent they turning on regardless what mode my switch is on.
Old Apr 17, 2015 | 10:23 AM
NickyP's Avatar
NickyP
I've heard them called City Lights here, I always have called them parking lights. I just got my G and haven't checked, but it may be the same bulb as the turn signal, so you may want to check that your signals are working too.
Old Apr 21, 2015 | 08:36 PM
properdropper's Avatar
properdropper
theyre called "city lights" bro to replace it just order a set off diodedynamics thats where i got my LED ones and theyre really nice
Slateg37
Sep 16, 2015 05:52 PM
hamwich
Aug 17, 2015 07:51 PM
GW330
Aug 12, 2015 12:19 AM
HB4LTHR
Aug 9, 2015 11:12 AM
reigle9
Aug 6, 2015 02:45 PM
