New G37S owner
Old Mar 15, 2015 | 01:43 PM
FrankieMigs's Avatar
FrankieMigs
New G37S owner
What's up everyone. Name is Frankie. Just recently picked up a 09 G37s coupe 6mt. I love it. Much bigger difference from my previous RSX type S. Anyways car has 66k on it. Bought from a dealer in PA. Has brand new brakes new tires and a brand new Infiniti clutch, pressure plate, and fly wheel. The car is amazing only problem when I shift and step on the clutch it doesn't always disengage fully like the pedal coming back up. I searched on here and ppl were saying about the clutch spring replacement. Could that be the issue I Am having. I work in a body shop so I am capable of doing the work. Get back to me and thanks.
Old Mar 15, 2015 | 02:03 PM
Hi Frankie, moved to this folder for proper intro. Glad you found us and welcome to the site.
The spring replacement should definitely improve the pedal.
Old Mar 15, 2015 | 02:08 PM
Sway_NV's Avatar
Sway_NV
I'm too young to die!
Hey, how ya doin? I came from an RSX type S too! Welcome to the G club. You're saying the pedal stays down and doesn't come back up? That's not the spring if that's the case... Sounds like the master or slave cylinder is out... Or maybe you need to bleed your clutch lines. It's possible it didn't get bled well when everything was changed out. I will say the spring from JSolo is a must! Super cheap but makes a world of difference.
Old Mar 15, 2015 | 03:01 PM
FrankieMigs
No the pedal comes back up just not as fast as it should. Just started happening yesterday. Had the car for 2 weeks n it only happens once in a while. Is there a big difference in the feel of the clutch pedal from the stock to the on jsolo sells. I like the feel of the clutch as is now
tom_lom
Jun 30, 2021 07:52 PM
Zach Stewart
Aug 18, 2015 05:01 PM
drkashifa
Aug 18, 2015 04:38 PM
Digilog
Aug 17, 2015 03:54 PM
cellwoot
Aug 13, 2015 04:27 PM
